Question about Canon PIXMA iP1500 InkJet Photo Printer
Cant make the printer stop in the middle to take the ink out
Had the printer given, I dont know what to press to make it stop so i can put a new black ink in ??
    Problem Solver:
  • 17 Answers
You need to make sure the printer has been on for at least 2-5 minutes so it can finish it's startup procedures. Then just lift the lid and wait for it to position itself so you can disengage the cartrage tray by moving the lever up. If the printer is not doing this for you, then there is something wrong with it and you can try unplugging the power for the printer when the cartrage gets close to the middle when it moves. Best of luck.
Posted on Oct 26, 2012
Testimonial: "Thanks a lot, its working now."
Diana-CISS
SOURCE: ip4200 stopped printing...help!
dear oceantracks maybe one of the black cartridge chip think that ink is running low or not ink is left in the cartrridge.
Posted on Jul 03, 2007
SOURCE: How can I print in " Black ink only " NO COLOR ?
I JUST PUT IN MY PIXMA MP 210 A NEW COLOR CARTRIDGEAND HE WONT START PRINTING.ALSO I CANT SCANNING ANYTHING WHEN CARTRIDGE IS NOT IN IT.IS IT NORMAL?
Posted on Dec 24, 2008
odiebugs
  • 949 Answers
SOURCE: cant change the ink
Try and open the access for the cartridge then turn it on. Unplug the unit and then plug it back in and try it. If it is under warranty contact them and see if they offer a solution.
Worst case is just slide it over manually, try and move it by the belt, cartridge itself, or
interface cable. Carefully.
Posted on Mar 20, 2009
SOURCE: my lights on my canon pixma mp160 won't stop
alarm.colour, & black lights keep on flashing and can't scan o print
Posted on May 22, 2009
  • 6 Answers
SOURCE: the ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Posted on Jul 24, 2009
Hp Photosmart 6510 Black ink will not print
It is a known defect among many PhotoSmart printers, including the 6510. The black ink was programmed to fail at between 50 to 60 black print cartridges. One HP whistleblower said a bug in this programmed failure causes the black ink to suddenly stop printing after 5 to 6 black ink changes instead. When you call in, they offer to sell you a new printer! The service guy I spoke with was extremely nervous. I refused to buy a new printer, given I had put less than a ream of paper through mine. I was on hold for about 10 minutes, then told there was no supervisor, but given an email address to write to. Three weeks later, still no response. Yes, a class action lawsuit needs to happen, not just for the printer malfunction, but for the hours I soent trying to fix it, and new cartridges I bought, thinking I had bad ones.
Jan 27, 2013 | Office Equipment & Supplies
Error 6502 came up on my viewing box and I cant get it to clear. I dont know what caused it exactly. I had a paper jam and I pulled the paper out of the rollers to clear it now I have error 6502 and I dont...
Pls do the following :-
Error code 6502 The Error code 6502 can occur in the printer as a result of ink tubes caught under housing and jammed the print head against the right hand side of the printer. The printer is unable to do anything now and it will give an alarm light only. To fix this issue, you need to unplug the printer and then plug it back. You need to press and hold the power button of the printer and click the Stop button twice. You can then release the Power button and press Stop button for four times. The issue will be fixed and you can start your print jobs.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX700 Office All-In-One InkJet...
Need all steps in changing black ink cartridge
Hi Good day!!! Here are the steps how to replace cartridges
1. Turn on your Epson Stylus NX100 Series printer. Your printer should be plugged in and connected to your computer.
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to show you which cartridge is low and needs to be replaced.
3. Press the stop button once more. If other cartridges need to be replaced, the printer head will indicate which ones by stopping on those cartridges each time you press stop. If no other cartridges need to be replaced, the print head will move replacement position on the right.
4. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
5. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
6. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus NX105 All-In-One Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Change print head on kodak 5300 printer
Are your asking how to replace the printhead?
First you need to turn On the printer and open the printer access door where you can see the Ink. Now wait for the Printhead to stop into the middle then remove the ink cartridges both ink and black., Now to rmove the Old printhead you need to press a Tab which is hidden on the printhead., heres the step to remove the printhead which for me the hardest part
-Point your index finger on the white sticker that attached on the printhead or the bullseye sticker(If theres no white sticker on the print head just put your index finger on the middle of the printhead)
-Now your index finger is on the middle of the white sticker right? Move your index finger upward unti you feel a latch that you can press., Just press and full then your printhead wil be removed
-Now Your ready to insert your new printhead
-To insert new printhead just put the printhead on the carriage of the printer and gently press the white sticker of your new printhead make sure that you will hear a clicking sounds then put your cartridges back
-Theres some instances that the printhead will not stay on the middle., it keeps on staying on the right or on the leftside for you to solve that heres the step
-Turn on the printer open printer access door and wait for the printhead move into the center and if the printhead its on the center immediately unplug the power cable so the printhead will not move.
GudlucK
Nov 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to install a new printhead in 5500
GudlucK
Nov 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I donot know how to put ink in my printer jnhb55564
first turn on you printer.
second open you cover then you will see the print head cartridge is running out i think he will stop in you left hand side or right hand side.wait for he stop running.
third after stop running plug out ink just press down ink about 45 degree then you can take out ink.remember when you put out ink see number ink before installation.
4.when install ink remember to take out plastic sticker gum inside ink.now install ink jus put in inside by 45 degree the press up him after that is ok
5.close the cover and try to print.i think black ink in left and colour in right i no sure but try .... ok....
Aug 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Need help with my printer canon MP190
I refilled my MP190 Black cartridge PG-37 by drilling a hole in the top (roughly in the middle) and using the syringe supplied with the ink refill kit. To make the printer work again, press and hold down the Stop/Reset button (on bottom right hand side of printer) for at least 5 seconds until the display reads 1 again. This bypasses the ink level detector and is explained in the trouble shooting section of the on screen manual supplied on the printer installation CD. It works. It then happened again with the colour cartridge, so I repeated the process. It worked again. This should also work for the PG40 and CL41 cartridges.
Apr 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Unable to clear alarm light
I have the same problem and happened after 2nd refill
the only answers I could find was that
  1. the copper strip with the dots could be dirty and need cleaning
  2. It could be overfilled and need ink drawn out
  3. It could just now be a faulty catridge
I tried the first 2 with no success but intent to keep trying to clean it and draw some more ink out even though it doesnt seem too full. If it still doesnt work I am going to just discard it and get another and keep re filling it as I have a second one that I use with no problems.
  • Also the printer has to be reset when a new re filled cartridge is used as it will still see it as the empty one. to do this if you dont know how.
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Nov 12, 2008 | Canon PIXMA MX300 All-in-One Printer
Printer head cleaning
Sometimes a cart doesnt work well because of mal manufacturing. Put in another brandnew black cart and do the cleaning cycle again. Its an advantage to use genuine brother carts! If you dont have any success try this: press menu then start/mono (b/w) then four times arrow up. maintenance should be displayed and the printer beeps. press arrow up til 7 is displayed. press enter. press arrow up til 6 in display. press enter. Display: Cleaning_All. press arrow up til 3 then enter: power_p all. Press start mono. machine starts power cleaning. After maintenance is displayed press arrow up til 0 (zero) then enter then 9 then enter. machine prints print quality sheet. In case there are only a few blocks in black repeat the above procedure. If you doesnt see neither any blocks in bk nor text after the second try be sure that your printhead is clogged and cant be cleaned anymore. This happens due to thirdparty ink which has pigmented ink instead of dye ink. Use only dye ink for brother printers!!!
Sep 18, 2007 | Brother DCP-110C All-In-One InkJet Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
57 people viewed this question
old marine
old marine
