Question about Qca Spas Dream Series Mystic Hot Tub with Flex Cover
Does manufacturers of hot tub cover offer warranty?
Posted on Oct 27, 2012
    Problem Solver:
  • 9 Answers
Some do but most make it very difficult. The two best companies for covers and after sale service is www.costco.com and http://www.hottubworks.com/
Posted on Oct 26, 2012
Is a cracked screen covered under the warranty?
Hi Abby,
Most manufacturers do not warranty "damage from handling, misuse, neglect, accident" as that is not they way their products are intended to be used. Warranties usually apply to defects in workmanship and failures not associated with the list of things above.
This is why 3rd party warranty companies such as "Square Trade" came into being. These companies will offere to extend your manufacturer's warranty to 2, 3 or more years and offer protection from the types of problems they do not cover - drops, submersion, breakage, etc. Cost is based on the product, cost, length of warranty term and extent of coverage. As long as it wasn't stolen - return all the parts of the covered device for repair, replacement or reimbursement. You can also usually insure these products as a special "rider" on your homeowners insurance, too. Contact your agent to learn about the availability and cost of this coverage.
Feb 25, 2015 | Tablets & eReaders
Tip
A New Hot tub cover will lower your Hot Tub Costs
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
  1. The hot tub cover weighs over 100 pounds.
  2. You need more then one person to remove the hot tub cover.
  3. The hot tub cover is ripped and torn past repair.
  4. Faded cracked and just aesthetically ugly.
  5. The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
on Sep 05, 2015 | Home
Tip
Hot Tub - Spring cleaning and Maintenance
Spring is a great time to change the water in your hot tub and clean or replace your hot tub filters. Drain and give your hot tub a good thorough cleaning to rid yourself of the winter season. Make sure that you clean your hot tub cover at the same time both the top and the underside. This will help the hot tub cover to last longer and perform better. Hot Tub Spring Cleaning Tips
on Mar 27, 2015 | Pool & Spa
Morgan hot tub
I found the drain snakes very helpful to unclog a drain even it is a bathtub. Dran snake found both hand cranked and power cranked. for home use, the hand crank is enough but for professional plumbing power cranked drank snake is best.
Learn more from here -
https://www.toolsfreak.com/best-drain-snake/
Jun 30, 2014 | Pool & Spa
Is there a good website to buy accessories for my hot tub? steps, cover lifter, etc?
i like the brand litehouse. you can see their spa accessories here:
http://www.litehouse.com/spa-accessories.aspx
Jan 28, 2013 | Pool & Spa
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
Brand new spa, pump doesn't seem to be working!
I imagine the clicking you are hearing is the relay at the end of the switch (air or electric) that is trying to turn power on the the pump. Since any of those issues would be covered under manufacturers warranty I would suggest you get in contact with them in order to retain your warranty coverage. Even if it turns out to be a disconnected wire or bad relay, fixing it yourself gives the manufacturer the opportunity to void the warranty and potentially leave you stranded with a mess on your hands.
Dec 30, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
WHAT DOES THE WARRANTY COVER
It all depends on the manufacture, Jacuzzi, Aquatic, Maax. They all have different warranties and what is covered. Best to call or e-mail the manufacturer of the tub with the date of pruchase and serial number.
Aug 27, 2009 | Maax Kashmir Hydromax Whirlpool with...
Will warrenty cover for tub ring deteration? The center ring of the tub that connect to the baskket is hard acylic and it broken. I purchase the machine in 2003. Is it suppose to be broken? Or is this...
I don't think this will be covered by warranty - unless you've been paying yearly.
I advise you to seek part replacement yourself online, purchase the correct part, and either fit it yourself or use a domestic appliance engineer.
Aug 04, 2009 | Washing Machines
Qca Spas Dream Series Mystic Hot Tub with Flex Cover Logo
79 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
