Joy media player PMP200 Not charging, turn off.
I just plugged my YARVIK joy media player PMP200 into computer USB port, and my MP3 instead of going in Charging/Transfer mode. Keeps blink and keeps getting hotter. I've been using it for 2-3 months with no problems at all. I think it is overheated. What i posibly could do?
SOURCE: RCA Pearl TH1101A MP3 player not charging battery
the rca pearl does not have an external power source, only the AAA battery. Just put in a new AAA and you're good.
Posted on Feb 22, 2008
  • 4 Answers
SOURCE: Ipod won't charge
The easiest thing to do to solve this is to reset the iPod. Apple has a small resetting program especially for this type of ipod. The program is free and downloadable from apple.com. Try this url:
http://support.apple.com/kb/HT1238?locale=nl_NL
If that url doesn't work, go to Apple.com, click support and choose iPod and search for reset utility to look for the download link. And if that doesn't work let me know and I'll send the program to you by e-mail.
O, the reset will erase all your music/data on the iPod.
Posted on Apr 25, 2008
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
SOURCE: 1 gb AMT MP3 player stopped working after 1 month
use flash Flash_Disinfector.exe
it flash ur mp3 memory
then go to tools>>folder option >>view>>
unselect hide protecting oprating system files
then select show hidden files
then you can easily seen the file" autorun.inf"
then go to cmd (run cmd)
change attrib by this command
type drive name from you want to delete
attrib -s -h -r autorun.inf
then
del autorun.inf
it will fix ur problem
Posted on Apr 14, 2009
  • 233 Answers
SOURCE: my mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
Posted on May 30, 2009
Sylvania mp3 player charge
Not all computer USB ports put out enough current to charge batteries. If you're going through a hub, try connecting it directly. Try a different USB port if you have one. Try plugging it into a wall outlet if if you have an AC-USB adapter.
Jan 04, 2014 | Audio Players & Recorders
How to charge a cativa AT-MP420 portable Media Player
Ti charge the MP3 player, connect the supplied USB cable to the player and then plug the other end of the USB cable into the USB port of your computer.
OR
Purchase a 5 volt mains USB power adapter and plug the USB cable from your player into the USB port on the power adapter.
Aug 13, 2012 | Toymax Audio Players & Recorders
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Hello
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
My sansa mp3 will not charge on my computer it just drains the battery instead. I have tried rebooting my computer but it still will not charge.....help I miss my music !!
Not all computer USB ports put out enough current to charge the battery. If you're plugging the Sansa into a USB hub, try plugging it in directly. If there's another USB port available, try that.
If that doesn't work, you may have to get a separate USB charger, as used for some cell phones.
Also, bear in mind that when the Sansa is connected to a computer, you can't listen to your music on it.
Oct 21, 2010 | SanDisk Sansa e260 MP3 Player
How do I charge my 1808L mp3 8gb portable media player
You should have received a short USB cord with your 1808.
First, turn the mp3 player OFF.
Next plug the small end of the cord into the bottom of the 1808.
Then plug the other end into any USB port of your computer.
You should get a popup message saying that your computer has found a new device, if not, after one minute, turn on the 1808.
The mp3 player charges any time it is plugged into the USB port,
Jun 07, 2010 | Eclipse TCH828 Digital Media Player
How to charge My Mp3Player
Hi giannuandi,
Plug it into a USB port, and it should charge by itself. Use the USB cord Apple supplied for transferring data.
Dec 05, 2009 | Apple iPod shuffle MP3 Player
I have a problem whit my driver
try charging the device directly instead of plugging it into the usb port of your computer.
Jan 29, 2009 | Creative Labs Zen Stone Plus MP3 Player
RCA M4002 mp3 does not turn on.
Download the latest firmware upgrade from www.rcaopal.com to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
-Tha Mp3 Doctor
Dec 27, 2008 | RCA OPAL M4001 MP3 Player
File system corrupted
press down on joy stick when you plug in USB cable to the lyra
Jan 29, 2008 | RCA Lyra RD2765 MP3 Player
403 people viewed this question
 Grubhead
Grubhead
