Question about LG 55LH40 55 in. LCD HDTV
NO SIGNAL ON HDMI PORT
TV turns on but says "no signal". Tried PS3 on different HDMI port - no signal. Tried HDMI outpuits on different TV, and the devices are working. It seems as though our HDMI ports took a dump. Any other reports of this?
  • 50 Answers
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Posted on Apr 27, 2010
  • 8457 Answers
SOURCE: I have an LG 47
Tries reset the tv and cable box,by unplug,replug both devices about an hour later.Let the cable boot up and update it softwares.Goto tv Menu goto PICTURE,go down to reset.The Tuner board it reseting to the Factory setting.The HDMI hubs,should all works now.Not than,the tv Tuner board have problems,must be change.Tries Shopjimmy.com,Ebay.com to buy a refurbish a Tuner board for the replacement.
Posted on Jul 15, 2010
bobhifi
  • 635 Answers
SOURCE: i have an LG42LH40 and
Are you aware that all the new HDMI devices have interactive technologies . For eg: if you are watching cable TV and switch on your Blue ray player connected via HDMI, you will notice the TV will automatically switch to that HDMI input with you having to pick up the Tv remote and switch manually. Some find it irritating, but you can disable that function in your system Menu. Panasonic calls it Vierra link / Sony calls it Bravia sync etc.....
Posted on Mar 08, 2011
  • 11 Answers
SOURCE: when we plug the blu
Hello
Unfortunately your TV is only HD ready. This means that it plays video in 720p. A full bluray disc is 1080p. Im afraid your tv will most likely not be able to handle a bluray player.
:( sorry
Hope this helps
Posted on Apr 03, 2011
budmrtn
  • 11361 Answers
SOURCE: i have an LG 42PC5D
It is because the PC video resolution is too high for the TV to display, you need to set your PC video resolution to the native resolution of this TV, see you owner manual.
Resolution: http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 01, 2011
Ps3 turns on but no signal on tv
Hi There,
Is the TV set for the correct input?
I assume you are using HDMI?
If all settings and input selections are correct then I will have to say that either the HDMI cable is faulty, or the HDMI port on either the TV or PS3 could be faulty.
Check if PS3 can work on another TV with the HDMI cable.
Check if another Device can work on that TV with the HDMI cable.
Try another HDMI cable.
From this, you should be able to determine where the issue is sitting.
Hope this helps!
Jan 13, 2016 | Sony Playstation 3 (PS3) Console
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
No PS3 signal on TV using HMDI or Component Parts
It could be that either HDMI port could be bad or you might want to try a different hdmi cable. The cable could be bad.
Jun 24, 2012 | Sony Playstation 3 (PS3) Console
Tv recognizes ps3 through hdmi but ps3 not giving a signal to tv
you could have a loose south bridge chip, you will need to do a re-flow.
also check any small resisters next to the HDMI port.
Jan 03, 2012 | Video Game Consoles & Games
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
LG 55LH40 55 in. LCD HDTV Logo
159 people viewed this question
Computer Repairing
Computer Repairing
