Question about Toshiba E-Studio 195 Digital Monochrome Multifunction Copier
Have installed original toshiba toner to e-195 after the starter kit toner finished,the machine is giving massege
Ir400 problem e240 error remove
Posted on Oct 26, 2012
2 Suggested Answers
  • 30 Answers
SOURCE: Dear sir,
Dear,
your copier e-studio 350 some time showing '' dispose used toner'' It dont mean you install new toner... its mean you dispose used toner box.. Dear open the copier frant cover
and dispose used toner white box...
Thanks
Best Regards,
Posted on Aug 14, 2010
How to reset error c2558 in bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :-
Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer.
Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine.
Step-3. switch Off & re - switch on the machine .
Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION.
Step-5. Press [OK].
Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR.
Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number
Step-8. Turn the machine off the main switch.
(finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside)
If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer.
Installing the toner bottle :-
Step-1. Before using the toner Shake the toner bottle.
Step-2. Open the front door.
Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle.
Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle.
-----GOOD LUCK-----
Aug 13, 2014 | Office Equipment & Supplies
Our toshiba e5520c colour machine shows an error code cd81. What can i do to solve the problem? Must i reset the machine? Can anybody help please? Thanks Yolande
CD81 is an error code for full waste toner bag, or waste toner auger is being locked up, all you have do is separate the finisher from the copier(a green lever inside the finisher door or hole punch unit door), open the side door on the left side, pull the the waste toner bag out, dispose the waste toner properly, then tap the waste toner bag lightly (to make sure you clear the light sensing area is clear for waste toner full detection), reverse the procedures -please consult your user guide. Better yet, ask your dealer give you a spare waste toner bag.
Jan 30, 2013 | Toshiba T-FC55C Toner for BR E-Studio...
Error code c2558 for konika bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :- Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer. Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine. Step-3. switch Off & re - switch on the machine . Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION. Step-5. Press [OK]. Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR. Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number Step-8. Turn the machine off the main switch. (finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside) If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer. Installing the toner bottle :- Step-1. Before using the toner Shake the toner bottle. Step-2. Open the front door. Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle. Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle. -----GOOD LUCK-----
Jan 15, 2013 | Konica Minolta bizhub C450P Laser Printer
Minolta bizhub 164 error code C2558..how can I solve
Step-5. Press [OK].
THATS IT - YOU ARE DONE - FINISHED
DONE - ERROR REMOVED
-----GOOD LUCK-----
Mar 06, 2012 | Office Equipment & Supplies
Hello I am French and don't speak very well english I do not have the power adapter for Toshiba 2180CDT/4.3 System Unit Model PS218E-E8180-FR With which other model i can replace it and how i can...
http://www.amazon.com/Satellite-1800-S203-1800-S204-2800-S201-4100XDVD/dp/B003U8I1ZA
Je pense que c'est le bon modèle que vous souhaitez. La meilleure façon d'obtenir une autre est de l'acheter sur internet. Désolé si quelque chose a été mal traduit, ma langue maternelle est l'anglais, et j'ai décidé de vous une faveur o en faisant de ce plus facile pour vous de comprendre.
Feb 16, 2011 | Toshiba Satellite 2180CDT Laptop AC Power...
What is a service code c2558 mean on my copier?
C2558: Abnormally high toner density detected black TCR sensor
Reinstall imaging unit
Reinstall toner cartridge
Change imaging unit/K
Change PRCB
Sep 28, 2010 | Konica Minolta Bizhub c203 Copier
Dear sir, my toshiba e studio machine some time showing "dispose used toner" . I thing that means tonner is finished. there have 4+1 toner which we need to replaces Idon,t know. Please help me
Dear,
Thanks
Best Regards,
Aug 05, 2010 | Toshiba e-Studio 350 Copier
Sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Jul 20, 2009 | Toshiba e-Studio163 Copier
Toshiba E-Studio 195 Digital Monochrome Multifunction Copier Logo
130 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
