Question about Freezers
Start/overload relay went bad on my Kenmore chest freezer model 255.19502010. Sears no longer sells the part. I bought a replacement relay/overload unit that ought to work. The wiring is a little diff
I have pictures of old wiring and new part.
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
dauphine
  • 207 Answers
SOURCE: Kenmore Chest Freezer
It might be freezing normally but that doesn't mean that compressor's motor isn't overheating due to lack of freon or mechanical problems on motor itself. Better not risk a fire and let someone experienced check the compressor's motor. Overheating is never a good sign.
Posted on Apr 20, 2008
refritech08
  • 149 Answers
SOURCE: Chest Freezer Wiring
hi mel,
green with yellow are ground wires and usually are from compressor to system chassis from your 3 prong plug use the green wire and just find a point on the chassis to pin to if you can get model number you can find on kenmore website
Posted on May 09, 2008
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Red light blinking with audible alarm. Compressor
That is the compressor starting relay trying to start the cooling cycle and the overload protector kicking off. You can try installing a new start device for about $50.00 but you are most likely looking at a compressor replacement which runs about $400.00
Sorry for the bad news
Apr 17, 2010 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore Chest Freezer Model number 1987191852 has started to defrost own its own. Compressor starts and shuts down after appx 2 seconds. Has this unit reached the end? is it cost effective to repair?
Good day,
That short cycle you hear, is the compressor trying to start, and can't.
It is possible one of the start components has failed. Under a cover on the side of the compressor are either 3 or 2 components.
The start relay, the protective overload and on some models a start/run capacitor. These components can be removed by pulling them off of the pins of the compressor.
Most appliance parts houses will be glad to test them for you. Replace any that test bad.
If all test O.K. then it is an internal problem with the compressor itself, which would take the services of a trained tech and pretty pricey.
Apr 11, 2010 | Kenmore Freezers
I have a freezer chest the compressor comes on but it never cools
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Nov 10, 2009 | Kenmore 8.8 cu. ft. / 249 liter Chest...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
My fridge freezer defrosted n now wont wrk
what you are hearing is the overload kicking in and out. which means bad start relay /bad capacitor/low voltage/bad overload/bad compressor.you can buy a 3in1 to eliminate all but the compressor. and the voltage check them first.
Dec 14, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore chest freezer.
Most likely a bad compressor. You could try a new relay on it first.
Nov 21, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
178 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
