Question about AKG K840 KL Wireless Cable Headset
K840 speaker Need to replace the speaker akg k840
I have these AKG K518 headphones but the left heaphone it doesn't work, so can you tell my how to fix it please
check continuity on the head phone jack to the speaker if all is well the speaker is to the issue..if not replace the wire but youll have to do so for both speakers
Jan 07, 2013 | Audio Players & Recorders
Right speaker not working akg k270
As monitors, I have used either the on-board speakers or headphones worn over the headworn microphone. In both cases, my own voice (as processed through 'Mike Effects' and VH) can't be heard over the music.
This is distinct from the recording on the USB stick where my own (processed) voice is in balance with the music.
Either I need an additional recording gadget to turn up the monitor volume of my processed voice while leaving the monitor volume of the music at a set level, or I have overlooked a setting somewhere. I am hoping for the latter (and I am still looking).
Honda Parts.
May 28, 2012 | AKG Audio Players & Recorders
How can i open my AKG k141 studio headphone to repair it ?
I had a problem with my AKG K141 Studio headset. The right side stopped working. Hard to believe but one of the leads to the ear speaker was disconneted from the solder lug. To disassemble, pry the gold AKG emblem using a jeweler's screw driver. You can pry it without damage by locating a small notch on the black plastic rim at the 6 o'clock position. Then unscrew ththe tiny phillips screw and remove black disc. You will see two leads (red and white) feeding through a hole. Disassemble removing a larger screw. This will give you accesss to the solder lugs.
Nov 30, 2010 | AKG K 240 Studio Professional Headphones
A year ago i bought an AKG k512 headphones .I really liked them ,but like a week ago the right headphone stopped working.What to do?
Hi,it might be due to the wire that has cut inside the speaker area.
You will need to open the speaker area, and check if the wires are still in place.
And also, if the wires are intact, You will need to replace the speaker inside the headphone, That will solve the problem..
Thanks for using fixya....
Oct 28, 2010 | AKG Audio Players & Recorders
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
akgusaservice@harman.com
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
Muffled sound
I wonder how it sounds on another amp/speakers?
Did the person/shop who cleaned it test on another system and say it worked ok? A good dealer of the
AKG brand should be able to verify a problem.
Apr 14, 2010 | AKG C414BULS Professional Microphone
Right speaker is not operating on a set of AKG headphones.
Go in by the part that fits to your ear. You will need to remove the ear pad. Also the foam, you might have to force the foam off, you can glue it back when done. With them gone you should see access screws.
Feb 16, 2010 | AKG K 240 Studio Professional Headphones
Did i blow my speakeres in my akg 701's
Blown speakers get replaced not repaired. U may have overdriven the units.
Jun 20, 2017 | AKG K 701 Professional Headphones
Akg c1000s replacement grille
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
Oct 07, 2009 | AKG C1000S Professional Microphone
AKG K840 KL Wireless Cable Headset Logo
27 people viewed this question
Top AKG Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you an AKG Radio Communication Expert? Answer questions, earn points and help others
