Libgaro_color error: 18000 - Office Equipment & Supplies
How to fix H5 error
Ipm is inverter protect. Replace PCB (printed circut board)
Oct 12, 2016 | Gree 18000 Btu 20 Seer Ductless Mini Split...
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Error code u5
AC current detected circuit malfunction.
Jul 06, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
Cooling capacity :18000 BTU/h Air circulation
check the amperage of the compressor if it is high better to replace.
Nov 30, 2010 | Ruud UBHC Air Conditioner
A carpenter was contracted to repair a kitchen for $18000, the work took him 6 hours more than he has estimated and as a consequence, he earned $100 per hour less than he had estimated. how many hours had...
I will try to solve it systematically so it will be easier to understand. Note: The solution involves solving a quadratic equation.
Let amount of hours estimated be x:
Expected rate: $18000/(x hours)
Time spent extra: 6 hours.
Totals hours spent: (x + 6) hours
New rate: $18000/(x+6 hours)
Now:
18000/(x+6) x
The new rate is less than old rate by $100, therefore we can make the above inequality equality by adding $100 to the new rate.
18000/(x+6) + 100 = 18000/x
Solve by cross multiplaction:
(18000 + 100(x+6) * x = 18000 * (x+6)
18000x + 100x(x+6) = 18000x + 108000
Simplify:
100x(x+6) = 108000 (cancel 18000x on both sides)
x(x+6) = 1080 (divide by 100)
x^2 + 6x - 1080 = 0
Solve the above quadratic equation by any method (completing square, factorization or quadratic formula)
x = (-b+-(b^2 - 4ac)^.5)/2a where a = 1; b = 6; c = -1080
x = 30 or -36 (hours cannot be negative so disregard this result)
Therefore x = Estimated time = 30 hours
Check:
18000/30 = $600 per hour x+6 = 36 $18000/36 = $500 or $100 per hour less than estimated
Nov 12, 2010 | Office Equipment & Supplies
458 people viewed this question
k24674
jasbo
jasbo
