Question about Home
I need to put a rcd in to run my shower. how do i wire it up to mains
Just need to no how to wire it up
  • Garry Oct 26, 2012
    what is rcd?
    New Friend:
  • 11 Answers
You should never attempt mains wiring unless qualified get an electrician
Posted on Nov 25, 2012
I need to put back flow restrictor in Grohe shower head due to drought, how do I do ?
are you sure that is where it needs to be . as I have never heard of them being attached to a shower head . usually they will be put on the main water inlet line to the home or business
Jun 21, 2015 | Grohe Home
When using shower the RCD trips. Doesn't happen every time.
I think steam is getting into some electrical device in the bathroom, perhaps a power outlet or a device plugged in to it, perhaps a light switch or fixture in the ceiling.
Not all light circuits have a RCD on them, and if yours does not, suspicion falls on the power outlet.
May 11, 2015 | Home
The rcd trips as soon as i turn the shower on
Get the shower wiring tested!
Dec 30, 2014 | Home
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
Sep 07, 2013 | Kitchen Ranges
My Mira Event Mk1 shower keeps tripping when i switch it on
It's wired with wrong cable if fitting a shower up tp 8.5 6 mm twin and earth needed if 9.5 or 10 fitted 10 mm twin and earth needed and fuse at mains box must be 45 amp
Sep 23, 2012 | Home
Have a mira sports shower. when i turn on at isolated switch light comes on but when i turn on shower light goes out. no sound of water coming to unit or electrical sound in unit.
Have you checked if when turning on the shower water the electrical trip switch turns off at the fuse board. If the shower does keep tripping the RCD then the shower is the problem.
Apr 01, 2011 | Home
No hot water
Check your fuse/breaker, should be a rcd switch. Depending when the shower was installed the fuse/breaker may be separate from the main fuse board, if it is an rcd switch it should be between 30A and 40A rating. If it is still fuse wire or cartridge fuse it should be replaced by residual current device.
Remember to turn the shower off in the bathroom before returning power to it.
Hope this helps
Apr 10, 2010 | Home
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
HOW TO INSTALL SHOWER IN BASMENT WHEN GRED BELOW
You will need to pipe the shower to your sump well if you have one or get one of those ejector pumps to pump it to your main line. Tap into main might want to consult plumber if intimated by such a project but with some piping knowledge you can do it yourself. Do your homework first, don't be afraid to ask questions. Make sure to put check valve in line also, so no shower water returns to your shower.
Oct 09, 2009 | Smart Solar Sun Jet 150 Fountain Pump
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Home Logo
318 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
