Question about Canon MG5250 Printer
My Canon pixma MG5250 has been working fine but now getting a message on laptop when trying to print that printer not responding, have reconnected it to my broadband but still no joy
ikechinedu
  • 184 Answers
SOURCE: Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
Select the name of the printer model to remove and select 'Uninstall.'
When the MP Drivers Uninstaller window is displayed, click 'Perform.'
When the confirmation window is displayed, click 'Yes.'
When the Uninstallation Complete window is displayed, click 'Complete.'
5. Reinstall the Drivers
Note:
The MP drivers can be installed using Easy Install or Custom Install.
Easy Install automatically installs the software which is in the CD-ROM.
This method is recommended if you are a first-time user.
Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
Close any antivirus software that may be running prior to installing the drivers.
Turn off the printer and disconnect the cable connecting the computer and the printer.
Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
At the main installation window, click 'Easy Install' or 'Custom Install'.
When selecting Easy Install:
(A) Click 'Easy Install'.
(B) Click 'Install' in the following window.
* Display varies according to the printer model.
When selecting Custom Install:
(A) Click 'Custom Install'.
(B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
When the License Agreement window is displayed, read the content carefully and click 'Yes'.
The installation will start.
Messages may be displayed during the installation of the application software.
Follow the instructions on the window and continue the installation.
When the Printer Connection window appears, connect the printer to the computer and power on the printer.
Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
3) Restart the computer.
4) Install the printer driver again.
For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
At the Print Head Alignment window, click 'Execute'.
Note:
* The Execute button may not appear for all models. In that case, skip to step 13.
* The Print Head Alignment can also be done after the installation of the printer driver.
When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
At the Do not start another operation until current one has finished dialog box, click 'OK'.
When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
At the Installation Results dialog box, check the content then click 'Next'.
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
At the Installation completed successfully dialog box, click 'Exit'.
Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Posted on May 22, 2009
  • 84 Answers
SOURCE: Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Posted on Jun 02, 2009
cene765
  • 787 Answers
SOURCE: Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Posted on Oct 15, 2009
SOURCE: printer cannot print-message (5B00)
it says check printer 5B00. what do I need to do?
Posted on Dec 18, 2009
jonniewalker
  • 1031 Answers
SOURCE: my canon pixma mp620 is plugged in,switched on but
unplug the printer from all source of power supply ,leave it for like 15min then plug it back.make sure the printer is proberly connected
Posted on Jan 10, 2010
How do I print a mirror image from canon pixma MG5250 mirror image?
In the printer driver settings, where you can select the paper type, you have to choose "other paper" and select "T-Shirt Transfer".
Jul 18, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
White Lines over Black Colour?
MAKE PRINT ALIGNMENT
IF THE PROBLEM PRESENTS
FALLOW LINK
PIXMA MG5250
May 07, 2014 | Canon MG5250 Printer
My Pixma MG5250 has run out of Cyan ink, how can i continue to print with just black ink?
With the canon single ink inkjet printers it is not possible to use only the black cartridges for printing. You will have to put a new cyan cartridge into the printer to continue printing.
Mar 06, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
My Pixma MG5250 has run out of cyan ink, how can i continue to print with just black? I use a Mac.
As long as the cartridge that is telling the printer I'm empty is in the printer, you can't go on. I did reset all my colour cartridges in my printer, because I only print in black. Still now and then a cartridge is telling it is empty. I think the printer still wants to mix colours in the black. Lucky me, I can reset my cartridges all the time.
I'm not sure you can do the same on the canon. Try to get a chip resetter that is sold on all refill stores.
Pixma error message U052
Try holding down the Stop/Reset button on the top of the printer for approximately 10-20 sec. It should start to print. If not try a different cartridge.
Jan 13, 2013 | HP Canon Mg5250 Pixma Pgi 525 Cli 526 Ink...
Hi there, I have a canon printer: PIXMA MG5250. I do a lot of office printing. Can you tell me how to change the setting to only print in gray scale? I like to safe ink usage as much as...
go to the Printing preference, then there's a a settings of Color that change into grey scale.
or if you have a drive /software of your canon PIXMA, theres a printer preference and a settings to grey scale.
Mar 21, 2011 | Canon Office Equipment & Supplies
CANON PIXMA MX310: printer not responding.
If you go to Start, Printers and Faxes, if it says "Offline", right-click the printer and choose "Use Printer Online." If it says Ready, you should be good to go.
If however there is a problem yet, double-click the Printer there and see if any jobs are in the print queue. You can remove them all buy Right-Clicking and choosing "Cancel All Documents" then try printing a test page. Right-click the printer, go to properties and click "Print Test Page."
If you still have problems, follow up on your question.
Aug 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Re: Canon Pixma MP530-- When I go to print the message reads " One of the USB devises attached to this computer has malfunctioned, and Windows does not recognize it. For assistance in solving this...
sounds like the usb port on the printer has popped . If u delete /uninstall the driver .Then reconnect the printer does it say "new hardware found" if not the port is blown on the printer
Nov 26, 2008 | Canon Office Equipment & Supplies
Canon MG5250 Printer Logo
845 people viewed this question
old marine
old marine
