Question about Refrigerators
Electrolux erf2832 integrated fridge freezer has major frost build up in the fridge section on the back wall. I have turned it off and removed the frost manually but when I turn it back on it begins to frost up again within a couple of hours. What is causing this and how can I fix it. Do I need a professional to come and look at it? Please help! Micheal
  • 151 Answers
SOURCE: Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
Posted on May 14, 2009
SOURCE: Fridge not getting any air, freezer is working
I have a Kenmore w/ freezer on bottom. The top vent in the fridge is ducted to the freezer and is supposed to blow air. Mine was not.
I removed all the frozen goods and took off the back panel (inside to unit) which had a little ice on it. Underneath the panel was a solid wall of ice......including the motor which is supposed to blow air up to the 'fridge. I'd bet a beer that is your problem as well.
The ice seized motor will not be harmed because it is resistance loaded.
The best part is with a blow dryer and some elbow grease...the fix is free! I hope it helps.
Posted on May 31, 2009
Maytag317
  • 1136 Answers
SOURCE: frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
  • 2468 Answers
SOURCE: Frost Buildup in freezer section
check the defrost heater in the evaporator compartment at the rear of the freezer for continuity,then check your defrost control if the heater is o.k. be it either an adaptive defrost or a timer type defrost control
Posted on May 23, 2010
heatman101
  • 43501 Answers
SOURCE: Amana AFF2534FES freezer has frost on back wall,
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 27, 2010
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
Dear Sirs, We have and Electrolux integrated fridge freezer. The upper part ( fridge) is not keeping things cold any more but the freezer is ok. Nothing wrong with door seals etc... We have turned...
ice build up is usually a sign of lack of airflow(possible fan). or failure in defrost. if fan is running something related to defrost. there are bimetals that need to be ohmed out and the heater as well. if you can comfirm these parts are good change defrost control.
Aug 01, 2010 | Refrigerators
I have a zanussi electrolux zx99/5w the freezer is working but the fridge isn't cooling down
LOOK INTO THE FREEZER SIDE AND IF THE BACK OF FREEZER HAS ICE OR FROST BUILD UP / THE PROBLEM IS A DEFROST PROBLEM . The ice build up is blocking the air flow through the cold coil . the correction would be to repl the heater of the a d c control whitch controls defrost .. hope this helps ,mm
Jul 22, 2010 | Zanussi ZX99 / 5 Bottom Freezer...
Hi I have an electrolux Rex FI22/10NFB no frost Fridge/freezer Lately its been making ice at the bottom of the freezer and at the top in the fridge what could be the problem?
look along the door seals to ensure they lay flat agaist the body, as an air leak encorages fros/ice build up even in a frost free unit.use a hot cloth to adjust.
Jun 20, 2010 | Refrigerators
Major Appliance
It sounds like the thermostat is not sensing when the fridge/freezer reaches it's set temperature.This will result in the compressor running non-stop and this causes ice build-up inside the fridge.See on what number (0-7) the thermostat is set on.If it is set on 7,turn it down to 3 and see if it makes a difference.If there is no difference it means that the thermostat is not sensing & switching the compressor off.You will then have to replace the thermostat.
Regards
Andre Nagel
Mar 15, 2010 | Freezers
I have a CDA integrated fridge/freezer, the fridge is working but
OK then have a look at the back wall of freezer is frost building up on rear panel?
Jan 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
Frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Mar 20, 2009 | Kenmore Freezers
I've got an electrolux frost free fridge freezer and it is not freezing. The fridge is cool and cold air is entering the freezer compartment but it is not cold enough to freeze the food. I've removed all...
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Aug 05, 2008 | Electrolux Refrigerators
Fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Jun 23, 2008 | Electrolux ERN2820 Bottom Freezer...
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
