Question about KitchenAid Kitchen Ranges
How to change hidden element in kitchenaid oven
HOW DOES ONE REMOVE AND REPLACE THE HIDDEN - BOTTOM ELEMENT ON A KITCHENAID CERAMIC TOP OVEN MODEL YKERC507.
  • 76 Answers
You have to remove the plate that covers that element
Posted on Jan 03, 2009
OVEN ELEMENT IS UNDER OVEN BOTTOM LINING,HOW DO I ACESS ELEMENT TO CHANGE IT?
without make and model I can't even google it to look at a picture. has to be similar to a gas oven then with access either from the back or bottom
May 11, 2015 | Kitchen Ranges
KitchenAid Model KESC307 has a broken oven heating element. Can you fix this yourself? How? How much is part?
Hello Tgilreath,
I understand that you are having a problem with you KitchenAid range. The oven element is broken and needs replaced and you would like to know the cost of the element.
I can instruct you on how to change the element in your range. However, I do not know if it is the top of bottom element and the change procedure is the same on both of them. However, when looking up the element to tell you where you can purchase and the cost I came across many different KitchenAid models that contained the numbers you gave. There should be more letters and numbers on your tag for the model.
The following is steps are how you change out your element:
1. Disconnect the power to the unit
2. Remove the lower back cover on your range (the one that sits directly behind your oven)
3. Locate the two prongs on the bad element sticking thru the oven wall and remove the wires
4. In the oven remove the racks
5. In the oven remove the two screws holding the element in place
6. Remove the element by pulling in forward
7. Install new element in Reverse
You can locate the element on Sears Parts Direct at the following web-page, however you will need the full model number http://www.searspartsdirect.com/partsdirect/part-model/kesc307?pathTaken=modelSearch&prst=0&shdMod=kesc307 You may also reply to this thread and I will get you a part number and the exact page you need to order the part.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | KitchenAid KESC307 Electric Kitchen Range
Burners are working oven is not working ?
The heating element may be burnt out, you will need to replace this element if it does not heat up when the oven is turned on, try turning the oven to broil if the top element heat up then indeed it is the bottom element and need replacing.
Dec 18, 2009 | KitchenAid KESC300 Electric Kitchen Range
Need to replace hidden bottom element on whirlpool gold GJP84900 how do i get to it
OPEN OVEN DOOR, LOOK FOR SCREW HOLDING ELEMENT TO BACK PANEL, TURN OFF POWER, REMOVE SCREWS, SLIP OFF WIRE EACH SIDE.
BOTTOM BAKE ELEMENT, TOP BROIL ELEMENT.
Oct 25, 2009 | Kitchen Ranges
There was a poof sound in the oven and the breaker jumped. I put the breaker back on and it jumped again,I put the breaker on and the top element work but the bottom element ..nothing. I think the baking...
Very likely - yes. Turn the breaker off first (there is usually always power to one of the terminals of the element). Remove the element and check for continuity. No continuity - replace.
Oct 13, 2009 | KitchenAid KEBC107 Electric Single Oven
Hidden bottom element not heating. Went to remove it and it had burnt through. New element doesn't get hot.
Assuming that you installed the replacement correctly, can you check the element with a resistance meter?
It's possible the replacement element you bought was faulty. But first, we want to ensure that the oven is otherwise functioning correctly. You'll need that resistance meter to check continuity along the red wire (i'm presuming) that connects your top and bottom element to your selector knob. Also make sure there are no internal fuses in your oven that may have blown.
Please remember to turn the oven off at the breaker board before working inside it.
Hope this helps, let me know.
John
May 09, 2009 | Kitchen Ranges
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Kitchen Ranges Logo
709 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
