Question about Zynga Cafe World
I have 33 spaces can i get more space to put stoves on
I keep earning 4x 6x 8x stoves but i am only alowed 33 in my cafe what do i need to do to get more stove space i have the stoves but no where to put them
  • clairedempst
    clairedempst Oct 30, 2012
    I have 33 space to put my stoves so now when i earn a new 4x 4x or a 6x burner i cant use it unless i remove a stove already in use i can only place 33 stoves in my kitchen at any one time and i have stoves in my invertry which r un used because i have no space to put them how do i get more kitchen space to put out my new stoves
How can i get the specs for hl-dt-st dvdram gt20n
It's an ATA device. (ATA / IDE)
At MAXIMUM:
A) It can play back DVD's at 8X speed,
B) Read CD's at 24X speed,
AND Write,
1) CD-R's at 24X speed.
2) CD-R/W's at 4X speed.
3) US CD-R/W at 24X speed.
4) High Speed CD-R/W at 10X speed.
5) DVD-R at 8X speed.
6) DVD-R/W at 6X speed.
7) DVD-R+ at 8X speed.
8) DVD-R Double Layer at 6X speed.
9) DVD-R/W+ at 8X speed.
The optical drive in a Toshiba Satellite L455D-S5976 Notebook PC, is a DVD Super-Multi drive, that is capable of using disks that are Double Layer, and R- or R+
In all actuality about what is the best burning speed, it is the Slowest speed that you can choose.
That is usually 4X.
However I would recommend 8X in all situations.
Makes a better burn, and is easily readable by other optical drives.
Makes it simple, huh?
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 10, 2012 | Toshiba Satellite L455DS5976
What ia the sulution of 3y-6x=-3
To find the solution, first find the value of y for each equation.
Then substitue one equation into the other so that you only the x variable left.
Then just solve for x.
Once you have a value for x, then you can easily solve for y.
So for the first equation:
3y - 6x = -3
3y = 6x - 3
y = 2x - 1
Now for the second equation:
2y + 8x = 10
2y = -8x + 10
y = -4x + 5
Since both equations equal y, they also equal each other, therefore:
2x - 1 = -4x + 5
Now just solve for x:
2x + 4x = 5 + 1
6x = 6
x=1
Now substitute x=1 into either original equation:
y = 2x - 1
y = 2 (1) - 1
y = 2 - 1
y = 1
Therefore the solution is x=1 and y=1
Good luck, I hope that helps.
Joe.
Nov 09, 2011 | Texas Instruments TI-84 Plus Silver...
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Dec 09, 2010 | Acer Aspire 4520-5582 Notebook
Ind the area of the region bounded by the two circles y=x^3-6x^2+
The first step here is to draw a rough sketch of the two curves, and find the two points they meet. If you set x^3-6x^2+8x = x^3-4x, then you can rearrange this into the quadratic equation 6x^2-12x = 0. Solving this tells you x=0 or 2 : these are the two x values where the curves meet, and they give the bounds on your integral.
When you sketch the curves, you'll see that x^3-4x is below x^3-6x^2+8x, so the thing you need to integrate is (x^3-6x^2+8x)-(x^3-4x), that is, 12x-6x^2. If you integrate this from 0 to 2, you'll have the answer you need!
May 27, 2010 | Computers & Internet
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Recording DVD-RW
Make sure the discs you are using are the same as the ones listed as compatible in the manual:
• DVD-RW ver. 1.1 / 1x / 1x to 2x, ver. 1.2 /
2x to 4x / 2x to 6x
• DVD-R ver. 2.0 /1x / 1x to 4x /
1x to 8x / 1x to 16x, ver. 2.1 / 1x to 8x / 1x
to 16x
• DVD+RW 1x to 2.4x / 1x to 4x / 3.3x to 8x
• DVD+R 1x to 2.4x / 1x to 4x / 1x to 8x / 1x
to 16x
• DVD-RAM ver. 2.0 / 2x, ver. 2.1 / 2x / 2x to
3x / 2x to 5x, ver. 2.2 / 2x / 2x to 3x / 2x to 5x
• DVD-R DL ver. 3.0 / 2x to 4x
• DVD+R DL 2.4x / 2.4x to 8x
Any brand can be used.
Jan 11, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
Zynga Cafe World Logo
16 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
