Question about Seagate (ST3160827AS) 160 GB Hard Drive
Bad cluster in hard disk
I hve a 360 gb sata hard disk. when i start computer every 1/2 an hour its restart because of bad cluster in hard disk. can i solve this problem. kindly guide me.
  • 38 Answers
You must run scandisk utility in windows to fix problem. Go to C: drive >> properties >> tools >> choose error checking >> select automatically fix errors >> then start >>
If proplem persists you must format the C drive there may be less chance of bad sector recovery...
Or contact your manufacturer tech support if your hardisk in warramty period.
Posted on Jan 03, 2009
I need firmware for Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule the task on restart then defragment your hard drive
http://download.cnet.com/western-digital-disk-manager/3000-2122_4-10008018.html
This file contains the most up-to-date Disk Manager drivers for Windows 95 and Windows NT 3.5.1. This file fixes numerous issues, especially those with IBM PS/1 Value Point machines. These drivers will replace Ddloader.bin and Xbios.ovl files that were installed with previous versions of Disk Manager.
hope this helps you
Oct 20, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
DISK RECOVERY
you could run the chckdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
hope this helps you
Sep 27, 2011 | Western Digital (WD5000AAKS) 500 GB SATA...
Whenever logs in Windows defender scans the hard disks and gives the bad sector / RAM faults and 37 % unreadable hard disk and ask o purchase the s/w to remove those fault.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error also run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Mar 27, 2011 | Fujitsu (MHW2120BH) 120 GB SATA Hard Drive
Hard disk common problems
first up
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
also
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | Samsung HM500JI 500 GB SATA Hard Drive
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Solve Bad sectors Problem?..????
irst connect your drive to computer then check its drive letter meand c: or d: or e:
then go to start > run> then type "cmd" then go to drive letter then type "chkdsk /r"
then it cheks your harddisk for eror.
Jun 09, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Hard drive model: HD103UJ (1000gb/7200RPM/32M) I connected it to the pc..but cannot find it..Do I need drivers or something?
If tou can find it in booting time on bios screen, Just goto,,, start>control panel>Administrative Tools>Computer Management>storage>disk management. You should see the new drive. Click on it and try import foreign disk . it should bring the disk. try making new oartitions there.
Apr 20, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate 20GB SATA hard disk not detected
Ok, look at the hard disks circuit board, look for rust or something suspicious.
Jun 19, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Not responding hard disk
The problem is that the hard drive cannot be read properly.
The list of the things that may produce such a problem is bad power supply, bad data cable, bad mainboard, too many unproper shutdowns that damaged file consystency and bad hard drive (the HD electronic board or the inner plates), anyway, if you can get windows to load up run a check disk with the windows utility here are the steps
1) press START
2) press MY COMPUTER
3) right click on the drive and choose PROPERTIES
4) press the TOOLS tab
5) press CHECK NOW
6) tag (V) both options you get in the new menu--AUTOMATICALLY... and SCAN...
7) if it is your primary HD you will receive a notice that the function cannot be performed at this time, answer YES
8) turn off the computer and restart
9) the check will start automatically on computer restart
If the problem continues BACKUP any important data (if you can) and take it to a repair shop, make sure they BACKUP your data BEFORE they try to solve the problem.
May 07, 2008 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
135 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Terry Allen
Terry Allen
Mark Taylor
Mark Taylor
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
