Question about Acer Computers & Internet
How do i widen my screen
I click something which i never noticed the screen becomes small
  • Acer Master
  • 32,281 Answers
Change the screen resolution, go to Control Panel - Display - Settings tab and change the screen resolution to 1024 X 768 or higher.
Posted on Oct 27, 2012
Tip
How to find a newly installed harddrive in Windows 7
Here are a few simple ways to find and work with,a newly installed harddrive in Windows7.
I hope this helps.
First click start,a window will pop up.You want to right click on computer.see picture below.
After right clicking on computer a new window will pop up.see below
Left click on manage and once again a new window will pop up,see below
9d842db.jpg You are now in computer management,left click on Disk management and the screen will widen in the middle. see below
98ae6c6.jpg As you can see I have two harddrives,your new drive will be listed but not ready to use.You will need to left click on the unformated drive,it will move to the upper portion of that same screen.see below
0b167a3.jpg When the drive is in the upper portion of the screen right click it and as seen above,you will have the option of formatting the drive.You need to format the drive only if it is new.Once the drive has been formated you will be given the option of selecting a drive letter,you can let the system set the drive letter,just read befor you click its fairly easy.If the drive has not showin up in the upper portion just right click and format from the lower portion as stated above.Thats it your done if you go back to the upper portion of the same screen and right click on the new drive and go to properties,then left click your new drive should look like the next picture.All normal harddrive operations can be done from this window.see below.8ebdf3d.jpg
If I've missed something I'm truly sorry,I just hope I have helped in some small way good luck.
on May 31, 2010 | Computers & Internet
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
Mar 30, 2012 | Computers & Internet
Hello all!! Having a problem with my rear
Is there no button on the bottom of the screen that has a small picture that looks like that? U press it and it will either widen or thin out the middle. If not browse around in the video options and look for it. It's some kind of "panning" option.
Jun 09, 2011 | Panasonic PT-56WX52 56" Rear Projection...
I would like to fix my lap top screen, I need to widen my screen to fit my lap top.. I have about 2 inches of black on both sides, How do i widen my picture to fit my screen. I| have a hp lap top with...
Right click on your desktop and click screen resolution. Increase your resolution. If you are not able to then you need to download your display driver. Search for device manager and go down to your display. If it has a broken or missing driver then go to hps website download and install the driver.
Mar 21, 2011 | Computers & Internet
Widen view to go across two screens - cannot now return to single
go to the video card driver manager ..(probably present in teh tray system in the right side on the task bar ) open it ..and default any setting s...
another thing to verify is the enabling or disabling of the second monitor...if you disable it ...this will default the view also to a single display
for laptops the short cut for this on keyboard is FN+F4..
but if it is a desktop ..Im not sure if it will work or not...anyway ..just look on the video card driver manager ...right click on it ..and open options or settings ..there you will find almost all you need for settings..
Apr 28, 2010 | ViewSonic VA1930WM LCD Monitor
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Widening around the border of picture
I suggest you read your manual.You likely have the picture setting on Panorama or Wide setting, and your manual should explain that Wide Screen pictures are stretched at the sidea to fill the screen.
Mar 03, 2008 | Olevia LT32HVM 32 in. LCD Television
Computers & Internet Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
