Question about Whirlpool Dishwashers
Whirlpool lympia 6th sense is beeping and showing F6, can anyone help?
SOURCE: Whirlpool dishwasher
We had same problem with our ADP 5966. An engineer over the phone said he thought it was related to machine being unable to drain. I checked the drainage pipe connection to u-bend under sink, and sure enough, there was a major blockage. Cleared that and hey presto, problem solved.
Posted on Oct 13, 2007
  • 6 Answers
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
GodBlessU
  • 3513 Answers
SOURCE: what does F7 mean on a whirlpool 6th sense washing
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
Posted on Jul 30, 2009
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
I have a whirlpool 6th Sense that shows no power, I have checked with multi meter and power is getting to the system, the terminals etc, but not working it was in the warming stage and just stopped.
Alan Bean, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Alan Bean), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool Refrigerators
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirlpool Diswasher 6th Sense - Flashing Error F6. Do you know that this means?
i had this problem - it indicates a water flow problem - i discovered that the top wiper arm jets were blocked with bits of rice/food - took it off and cleaned it out as best i could , and machine working fine again
Jun 14, 2009 | Dishwashers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Whirlpool 6th sense front loader awm 8121
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Dishwashers Logo
428 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
