Question about Microsoft Xbox 360 Console
Xbox360 live i do not know my ip address
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
This is rare problem that you are facing... you can solve your problem using repair guide...click here for your help...
Posted on Dec 26, 2010
If you are using XP, click on Start on the bottom LHS of your monitor and then click on 'Network Connections'. In the box tha appears on screen you will see a list of your network adapters. Right click on the adapter that says Local Area Connection, Connected and in the small drop down list click on stutus. You will then see a box with 2 tabs, General and Support, click on Support and you will see your IP Address, Subnet Mask and your Default Gateway. If you are using Vist, its much the same procedure except you click on Network, then click on 'Network and Sharing Centre' and then over on the left side under Tasks, click on 'Manage Network Connections'. From there its basically the same procedure as in Win XP. You can also access the same info by right clicking the little network icon on the task bar and do as above in Vista and XP.
Posted on Mar 31, 2009
  • 3 Answers
Just plug in your ethernet wire to the back of your xbox and go to the dashboard on xbox and settings then test connections....
I'm trying to turn on DCHP on router to establish network connection for Xbox Live
According to the generic version of the manual for your router (Because you did not say which broadband ISP you were using) the DHCP server is on by default in the router, so unless you turned it off it should be on and trying ti pass out IP addresses
My Xbox360 sometimes has problems dropping its connection because I use Wi-Fi. If you can use a wired connection that would be much better.
If you did change the DHCP server settings and turned it off, you will have to setup the Xbox by manually assigning an IP address, Subnet mask (usually 255.255.255.0) and the default gateway (Also displayed as GW).
The only other setting you would need to add to the Xbox360 is the DNS server but you should set that to the same IP address you used for the default gateway.
Hope that helps.
May 19, 2011 | Actiontec (GT704WG) Router
Xbox360.cant get in to games online.my nat is saying strict,when before it was open
Your IP address may have changed or ports need to be forwarded in your router. Follow this guide from Microsoft to solve the problem:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
Jan 03, 2011 | Activision Guitar Hero Warriors of Rock...
I have eveything hooked up so hat i can get on the xbox360 live but it keep sayin that i need a ip adress
You need to get your service providers' settings to be able to use the router for internet connection. If you are just using it to connect your systems for home using and you are not going to the internet, during your setup you will be require to enter an IP Address. Just enter an IP address like 196.254.100.10, subnet mask as 255.255.255.0.
Jun 18, 2010 | Computers & Internet
I have window vista professional and I am trying to make connection with xbox360 live and I am using a cricket broadband modem. It is givning me an error of no Ip address found. how do I make it recognize...
Do you have a computer with wireless connectivity?
if yes then there is something that u should try first/
Enable internet connection sharing on that computer and connect it via ethernet cable to your xbox
and assing the ip address manually, the default gateway would be the ip address of the computer
if you are able to connect via this method then you need to speak to your ISP
Feb 12, 2010 | Microsoft Windows Vista Ultimate Edition
Xbox connected through network cable to pc ! what do i need to perform on pc through my wireless usb port connected to go online
If you are running Windows Vista on your PC here is how you can route your XboX360 through your PC/Laptop in order to get on Xbox Live Wirelessly:
1. Set up a Static IP address in Vista. Go to Start -> Control Panel -> Network & Sharing Center -> Manage Network Connections
2. Right-click on Local Area Connection and go to Properties
3. Double-click on Internet Protocol (TCP/IPv4)
4. Set the option to "Use the following IP address"
IP Address: 192.168.100.1
Subnet Mask: 255.255.255.0
Default Gateway: blank
5. Just to be safe, also set the options to "Use the following DNS Server Address"
Preferred: 208.67.222.222
Alternate: 208.67.220.220
(You may use your ISPs DNS entries also, these are just the OpenDNS ones that should work for everyone)
6. Under the "advanced" tab, you need to check "Allow other network users to connect through this computer's Internet connection."
7. Right-click on your wireless connection, go to properties, click the "advanced" tab and check the same box to allow other users to share the connection.
8. On your Xbox360 go to the network configuration menu and enter the following settings:
IP address: 192.168.100.5
Default Gateway: 192.168.100.1
DNS1: 208.67.222.222
DNS2: 208.67.220.220
Now you should be able to get on the internet with your Xbox as it will be using your PC/Laptop's wireless connection.
Jan 04, 2010 | Microsoft Xbox 360 Console
Cant get on to xbox live using wired connection
If you are connecting the system directly to your Broadband Modem than your ISP may have your regularly connected computer's MAC address logged in their system. Generally only Cable Modem companies do this, so to see if that is the problem do the following:
1. Locate your Cable Modem
2. Flip it upside down and locate the MAC address, it should look like this:
3. Write down the MAC address
4. Now turn on your Xbox360 and go to the network configuration menu.
5. find the part that says CLONE MAC ADDRESS and then put in the MAC address you wrote down.
6. after the settings have been entered back out to the main menu, and power off, then power back on your Xbox360, you should be able to get on line now.
Jan 02, 2010 | Microsoft Xbox 360 Console
Right ip adress in xbox360 but it keeps failing..?
You don't set the IP address (You can but that's a whole nother story, IP address' have to be unique to the device), you need to let your router assign one automatically. Two devices on the same network can't have the same IP address or it will fail to function completely.
Dec 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 live
i have everything hooked up but when i go to get on xbox360 live it tells me that my ip address failed . i do not know what that means.
Aug 24, 2008 | Microsoft Xbox 360 Console
Connecting to Xbox Live through my Dynex-E401 Router
You would think that Xbox 360 would be perfectly compatible with UPnP. They should be communicating with each other just fine, (UPnP talks to NATPMP to automatically open and forward appropriate ports), and the game's datastream is probably entirely connectionless aside from the initial handshake (UDP).
To log into your router console, type "http://192.168.0.1" into your browser, for the username enter "admin" and do not put in a password. To enabled Demilitarized Zone (DMZ), click ADVANCED and on the left side click DMZ.
You will need to know the internal IP address to the XBOX360, which can be found on the "CABLE TEST" or "LAN" page in the router console.
If you find that you cannot log into the router console with the supplied information, you need to press the little reset button with a pen for like 10 seconds.
If you cannot reach the router console at 192.168.0.1 then you need to go to Network Connections in windows and find out the "Default Gateway IP" which is the router's internal IP.
The XBOX360's internal IP address will be in the same format as your computer's (if you only have one computer, the XBOX360's IP will probably be 192.168.0.101 and your computer's should be 192.168.0.100). All of these are default values. You can change them in the router console as you please.
Jan 17, 2008 | Dynex DX-E401 Router
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
