Question about Electronics - Others
How to remove write protect on a memory stick
The stick has no switch on it, and I can't find how to remove write protect
  • 27,725 Answers
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hop this helps
Posted on Oct 29, 2012
3 Suggested Answers
  • 78 Answers
SOURCE: PSP Sony memory stick has write protection how do I remove this
You should have a small notch on the memory chip itself you just need to switch that off. look closely cos this might be very small.
Posted on Feb 28, 2009
kid_ant
  • 881 Answers
SOURCE: HOW CAN I REMOVE RIGHT PROTECTION ON MY MEMORY
It has no write-protect switch. You must have done something wrong that's why your getting an error. Back-up your files from that MS and format it.
The format may not work the first time, so you need to try it again and again until it works. The best thing to do is to restart your computer if the format fails.
Posted on Jun 08, 2010
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Accidentally switched my sandisk memory to 'lock'
Locking the card simply protects it from writes. It does not wipe out anything that was on it already.
If you're asking about a Memory Stick, there's a switch on the back. Slide it away from the "LOCK" position. If you're asking about an SD card, there's a switch on the side. Slide it toward the metal contacts.
Jan 29, 2013 | SanDisk 16GB Ultra II 15MBS Memory Stick...
My usb memory stick is write protected,how do i remove that?
The adapter has a tiny switch on the side opposite the notch near the pins.
The switch needs to be towards the pins, not away from them.
Apr 06, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
Want to copy some files to a memory card from a laptop but it says that the memory card is write-protected. how do i remove the write-protection to copy the files.
Some memory cards are having a write protection switch integrated on the side or on the back of the memory card for preventing the content from being erased or overwritten by accident, just like floppy disks. Both SD Memory Card and xD-Picture Card have their write protection switch on the side of the memory card in contrast to the Memory Stick PRO and some Memory Stick Duo that have their switch on the back of the card.
The SmartMedia Card is also supporting write protection but not with a switch. For protecting the SmartMedia Card's content you need to put a sticker on the card's write protection pad. It is the circle that can be found in the middle of the card, when facing the front of the card.
Oct 24, 2010 | Computers & Internet
Hey gurus! my memry stick has a write protect. please remove it.!
There is a little grey button on the side of the stick. Push it up or down.
Oct 03, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
How to remove usb write protection with notebook
Are you having trouble writing to a USB memory stick and you get a message that the USB memory stick is write protected?
Some memory sticks have a small slide switch which you can select to write protect the data on the USB memory stick.
Jun 18, 2009 | Acer Aspire 4720 Notebook
Cant format
you can remove the write protection status by inserting it to your camera and in the preview mode click the button menu, in that scroll down for options and you can see there the option for protection on or off. toggle that option.thanks for using fixya!. please dont forget to rate my solution.
May 28, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
How do i remove write-protection from MemoryStickPRODuo from psp?
1. Remove memory stick from psp
2. Plug in usb cable and start usb connection
3. Insert memory stick and now you should be good
For some reason you might have to repeat these 3 steps everytime you want to access your memory stick
Hope this Helps
Apr 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Feb 22, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Sony Cyber-shot with Magic Gate memory stick
there is a switch on the back of the memory stick to lock or unlock switch to unlock.
Feb 18, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
