Question about EuroCave Compact Wine Cooler
What refrigerant does the Eurocave compact Vieillitheque uses
Replacement power cord for Eurocave wine art
Fixya does not sell replacement power cords.
Oct 10, 2016 | EuroCave Refrigerators
When plugged in, the compressor doesn't activate. When you press the test button, the compressor turns on. After doing that about fivetimes, the compressor won't even flip on? This is a Eurocave Model...
if you keep starting it it will quit any way . but this sounds like a start relay or a bad or run cap / but you could have a bad compressor also . and if running on a long ext cord it cause this problem so ck these / hope this has helped mm feed back pls ..
Nov 25, 2010 | EuroCave S256T Wine Cooler
Thermostats are not working; unit is freezing up inside;
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
defrost timer is not working..
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | EuroCave Comfort 260 2-Temperature Wine...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
EuroCave Compact Wine Cooler Logo
Top EuroCave Refrigerators Experts
 steve
steve
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
