Colours wontalign on ricoh mpc4500, starts colour registration but wont finnish it any suggestions
  • 903 Answers
SOURCE: The colour settings are not right on my Ricoh
On the CL7100, you can run the color calibration procedure, and the machine should set itself up for optimum color. Just go into the menu, and under the Maintenance heading choose Color Calibration.
Is the color still off after running the calibration? Is it only one specific color, or all colors? What about when you only print black & white?
The image density should typically be left at the default values for optimum print quality. However, if you need to adjust it, you can go from -3 to 3. In the menu, go to the Maintenance category and then choose Image Density and then the color that you want to change. Adjust the value and press Enter, then run a test copy to see if it helps at all. If not, reset it back to the value that it was (probably 0).
If only one color is giving you a problem, even after running the color calibration, you might need to replace the developer unit for that color.
Posted on Sep 06, 2010
  • 903 Answers
SOURCE: With colour output from a Ricoh SP C222SF Aficio
Are the lines dark or light? You can try replacing the toner to see if that clears it up.
Also, go into the user options -- if you see a setting for something like "toner save mode" turn it off. That can cause poor copy quality and is sometimes turned on by default.
Posted on May 29, 2010
FingerStrong
  • 190 Answers
SOURCE: colour cartridge is not working properly. red
try to reinstall the printer driver then restart the printer and computer. you can download the latest printer driver from your printer manufacturer's web site.
Posted on Jun 11, 2010
  • 22 Answers
SOURCE: my Ricoh Aficio SPC811DN printer keeps asking me
The PCU is the drum unit. There is one for each colour (C,M,Y & K). Each PCU has a 'life' and the machine will ask you to replace it when it has reached the end of its expected life. The PCU life has nothing to do with the amount of toner that you have in the cartridges and they need to be changed independantly.
Posted on Jan 18, 2011
  • 903 Answers
SOURCE: I have a Ricoh 2238c. Are the drum units different
All four drum units on the 2238C are identical (part #B1909510). Each drum unit can be used for any of the colors.
Thanks for using FixYa!
Posted on Feb 12, 2011
Ricoh c4000 showing colour registration not compieted error, how to resolve
SP -21111
START EXECUTE C THEN B AND A
https://youtu.be/ivE83hRsJuQ
Dec 19, 2016 | Ricoh Office Equipment & Supplies
Why is our ricoh mpc4500 printing blotchy pictures?
Hi Jennifer;
just find out which color make the blotchy, go to replace that color drum cleaning blade, it should take care your problem.
Jun 18, 2014 | Ricoh Aficio Mpc4500 Mpc3500 Yellow...
Color registration
In user tools there is a maintance button press and then try color reg adjustment. If it doesn't sink color back in alignment it will say fail will need to call a tech . Could be anything from transfer unit bar that is shiny usually toward exit side cake with toner to laser failure
Jan 15, 2014 | Ricoh Aficio AP3800C Laser Printer
My printer is printing back to front. Have I pressed a wrong button or is there a problem with my printer?
This is usually a setting in the printer driver. Open your Printers and Faxes from the Start menu (Windows XP), right click on your printer and choose properties. Look in the tabs for printing preferences and then look in there for reverse print (or something similar) then deselect the option. If it is already deselected, it could be the application you're using has set up settings for the printer associated with it. In this case, you would check for the same thing from within the application that is causing the issue before you print.
Apr 06, 2010 | Office Equipment & Supplies
Won't turn on....
Have you recently replaced the colour PCU? It may not be seated properly, otherwise there is likely a problem with it, and it's not turning (ie: a broken gear). It could also be the PCU drive motor, or control board. Sounds like you may need a tech to get to the root cause unless you have a spare PCU to try?? This also explains the colour registration problem.
Feb 23, 2009 | Ricoh Aficio CL2000N Laser Printer
HP 1220 c printing is Blue
the printer uses a tri color cartridge seems like the cyan is finnished.install a neww colour ink cartridge
Mar 13, 2008 | HP DeskJet 1220c InkJet Printer
Colour and black and white
Colors registration need to be adjusted. It's a long procedure to describe. But if you are close to PA or NJ PhillyCopiers.com can do it for you.
Sep 17, 2007 | Ricoh Aficio AP3800C Laser Printer
103 people viewed this question
jasbo
jasbo
