Question about JVC Car Audio & Video
Jvc kd-r310 wont turn on
I now have no power to the face plate, what can i do to fix this?
GARYDALE
  • 15 Answers
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Posted on Sep 25, 2006
SOURCE: My JVC KD-SX650 WILL NOT POWER UP/JUST DOES NOT WORK?
your battery and accessory wire need to be twisted together. if u already have it like that then im not really sure other than that
Posted on Jul 12, 2008
MECP Guy
  • 344 Answers
SOURCE: jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Posted on Apr 26, 2010
  • 57 Answers
SOURCE: JVC 200W CDRW KD-S30 removable face car stereo.
HERE IS A LINK FOR THE USER MANUAL.
http://books.jvc.com/Download/393893894/GET0174-001A.pdf
HOLD SEL FOR MORE THAN 2 SECS. SELECT CLOCK USING FF/REW BUTTON TO VIEW HOUR/MINUTE. USE VOLUME TO ADJUST HOUR/MINUTE. PRESS SEL WHEN FINISHED. PRESS DISP TO VIEW CLOCK
Posted on Aug 18, 2010
nsanedrummer
  • 50 Answers
SOURCE: how to set time & color on KD-R310
To set the time for this unit, press and hold the menu button. Press the track advance button ">>>" til it reads clock H, then rotate the volume knob to adjust the hour. Press the track advance button again, and it will read clock m. Rotate the volume knob to adjust the minute. Then press the back button and it will take you out of the menu. The color can be adjusted from the button that says color just about the menu button. You can adjust the color of the screen, the buttons, or both. Hope this helps
20 year car audio/video installer
Bay manager
Posted on Apr 06, 2011
When i power up gateway screen is black
Most likely, its a power supply issue. Have fixed a couple of these by replacing bad capacitors on the power supply board. A bad capacitor will have the top bulging, not flat on top as it should be. The way to get the monitor apart is a little tricky. You will need to remove the screws around the top, sides, and bottom, Do Not remove screws on back in the middle. These screws hold the metallic pan that houses the power supply it's self. I used an orange pealer from Tupperware to pray the front face plate away from the back. You can use a screwdriver, if you don't mind a little marring on the face plate plastic. It's not easy removing the front face piece, lots of interconnecting plastic locks all.around the front face plate. Using your pry tool and pulling (you'll need to use a little muscle) to get the front off. Once face plate is loose, you'll notice the screen is connected to the power supply, one in the middle usually can be pulled and disconnected using your hand. I suggest taking pictures before removing the other wires holding the screen to the power supply. At this point, the front plate is removed, and the screws holding the the screen have been removed, wires disconnected, and power supply in view. Best of luck
Nov 10, 2013 | Gateway FPD1960 19" Flat Panel LCD Monitor
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
I have a non-lighting Cobra 29 NW face plate, or EL Driver problem . EL Driver is the small metal box mounted inside, to the side, of the the Cobra 29 near the channel selector control . Can anyone tell me...
that is a power inverter. dc to ac inverter. 13-14volts to 40+ volts ac. to run the el display.. if the display is pulled away from the face like the glue is coming loose that indicates the el display is burnt and will not work unless replace the face plate the el face.. you should have 45volts AC on the two wires feeding into the main chassis face to the el display.
Nov 28, 2009 | Cobra 29 LTD CB Radio
Face plate wont light up but power is getting to it
make sure face plate is firmly put in place with no obstructions hindering the circuits behind face plate
May 20, 2009 | Car Audio & Video
Left side of face plate not locking in no contact
Try cleaning the face-plates electrical terminals with small amounts of rubbing alcohol and cotton swabs, also remove the fuses to the head unit then clean the receiving terminals in the same fashion, allowing all to completely dry before attempting to operate.
Good luck
Aduz
Mar 27, 2009 | Lanzar VBD1100MP3 CD Player
Face plate buttons wont work
This is actually a common problem with more than just that radio. Sometimes the pins on the back of the face plate need to be cleaned. Take the face plate off, take a Q-tip and dip it lightly in some rubbing alcohol. Then use that to clean the metal pins on the back of the face plate. Make sure it is completely dry before you place the face plate back on. If this does not work, your better off replacing the whole thing.
Jan 20, 2009 | Alpine CDM-7874 CD Player
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
Sep 25, 2006 | JVC KD-S680 CD Player
Car Audio & Video Logo
139 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
