Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
My mp250 copier wont print or scan and the paper rollers is only turning on one side mp250 canon
The printer wont let the paper go through straight and it wont scan and the rollers are only working on one side
  • edinathomas
    edinathomas Oct 26, 2012
    throw it in the trash and go get another printer
  • 1570 Answers
SOURCE: My canon pixma MP470 printer
Hi
Please inspect again for paper jam located inro the paper tray, in the ink cartridge compartment and rear door of the printer (back door of the printer). If you find the paper jammed, it solves you problem and try to print again.
If not, just open the cartridge door, turn off the printer and move the cartridge using your hand the ink cartridge to the left going to the right and then right to left for 2 times. Then try to print again, also jammed message errror is related to stuck up cartridge.
Posted on Feb 26, 2011
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 3 Answers
SOURCE: printer grabbing the paper very rough, jamming inside
CHANGE YOUR PRINTER DEFAULT
Posted on Mar 01, 2009
  • 16 Answers
SOURCE: MY PRINTER
in the small moniter what the errore you have like E5 - E2- E3 so that we can help you this Errore know you the problem on the printer
Posted on Dec 02, 2009
SOURCE: canon mp250 paper will not feed snags on something
I had a paper feed problem with a Canon MP 250 and solved it this way. (not my own)
After many attempts t clean the feed rollers etc. I tried the following.
I cut a piece of card stock about two inches wide. I fed this sock from the front to rear and carefully worked the card stock in and out and from side to side (flossed it) and dislodged a drywall screw !!
I realize that having a drywall screw lodged in the paper feed is not common, however this "flossing trick may help to clear the paper feed path in other situations.
Posted on Dec 05, 2010
Paper jams after pulled in skew
Mine did this ages ago. I found a staple had accidentally fallen into the printer and jammed on one side causing the paper to go in skewed and then jam up. Get a torch and have a really close look inside where the rollers are for staples, paper clips or bits of paper stuck on the rollers.
Aug 28, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Canon mp250 error no paper
Get a q-tip and wipe roller with rubbing alcohol on the q-tip. This should renew the friction ability of the rollers.
Jan 03, 2013 | Canon Pixma Mp250 Allinone Inkjet Photo...
The paper is misfeeding to the right
clean the rubber roller carefully so it can guide the paper again properly canon ink cartridges
Dec 03, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Image print on paper slanting
Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
Jun 05, 2009 | Canon NP 6545 Copier
Wont scan from adf. also bends corner of paper when printing
f your printer is unable to pick up paper and the feed rollers are turning, remove the rear access door and clean them with a cloth moistened with water.
Jan 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
56 people viewed this question
old marine
old marine
