Question about Toshiba Satellite A135-S2276 Notebook
Web Camera says something
When I tried to use Web Camera is says "blocked by another application". What does this mean. I just got a new camera for Christmas and downloaded the hardwear but it was working up until today.
How can i use my hp probook inubuilt cam
If you use Skype or some instant messaging, chat, video calling program it will sense the presence of a camera and will ask you whether you want to use it.
For HP laptops there is usually an application software installed that allows you to use the camera. Look in the list of programs for something that may be named my camera, HP web camera, Camera application. etc.
Oct 15, 2013 | Computers & Internet
I have Toshiba laptop with built in camera, but whenever i try to open the camera i recieve an error message 'CEC_Main.exe' reinstall. Kindly help how do i go about.
You also have Kasperkey ?
The error message 'CEC-MAIN.exe' is connected with the Camera Assistant Software,
You are unable to run the camera software because your KIS (Kasperkey Internet Security is blocking it by keeping "CEC-MAIN.exe" in the 'Untrusted File'.
Resolution:-
1) Launch your web browser
2) In the Notification Area (Down by your clock - Right click on the KIS icon and select "Pause Protection" > select "Resume manually"
3) In Notification Area: click on KIS icon elect "Applications under Control"
4) In the "Applications under Control" menu relocate "CEC-MAIN.exe" from the "Untrusted File" to the "Trusted File" - click "OK"
5) > Start > All Programs > CEC-MAIN icon to run your web camera program
Or My computer >> Local Disk (C) >> Program Files >> Camera Assistant Software Folder >> CEC-MAIN icon
Your webcam should now be running
Worth putting a shortcut on your Desktop at this stage .
6) With the webcam still running, then In notification Area - Right click on the KIS icon and select "Resume Protection"
7) Check the "CEC-MAIN.exe" in "Applications under Control" and confirm it is still in the "Trusted File"
8) Restart your computer
Aug 19, 2010 | Computers & Internet
I have sony vaio VGN-FE880E my web cam not working
Please try downloading and installing the Microsoft Update KB931812 and VAIO Camera Capture Utility Update from Sony eSupport Site.
Download the Microsoft Update here
Download the VAIO Camera Capture Utility Update
If the issue persists, please try re-installing the Camera Driver and the Camera Application in the Computer.
Download the Camera Driver
Download the Camera Applications
This should fix the Camera issue.
Aug 16, 2010 | Sony VAIO VGN-FE880E/H Notebook
Whenever i open up my camera it says "could not start the camera. close other applications and try opening again."
Hi, when a camera says could not open the camera close other application and try again ,means that either to much application where opened at a tie or the camera is corrupted.
First, scan through phone and see if unnecessary applications where open,If not, that means the camera is faulty and will eeed to be replayed.
Aug 07, 2010 | RIM BlackBerry Bold 9700 Smartphone
Acer orbicam problem
What application are u trying to open ?
Make sure that in that application settings at image input / camera or something similar u select your laptop`s camera.
Aug 07, 2009 | Computers & Internet
Web camera
did you install the driver for the webcam ? or just the software try this press your windows key ( by the alt key) and pause break ( uper right corner)
then goto device manager
look for any yellow or red x's probly will be one for your camera or it maybe listed in other devices
Mar 24, 2009 | Toshiba Satellite A205-S4617 Notebook
I can't install the Icecam because of Finder applications
Are you running OSX 10.4? Not supported yet...
  • Mac OS 9.2, Mac OS 10.2, Mac OS 10.3
  • Elsewise call MacAlly support or Apple.
    Mar 12, 2009 | Macally IceCam Personal Web Camera
    Urgent
    go to device manager, check under imaging device.
    check the manufacturer (it should not "microsoft").
    download camera application from www.acerpanam.com.
    if the manufacturer is microsoft, go to www.acerpanam.com and download all camera drivers (there are 3. bison, suyin and logitech). install the camera drivers first and then the camera application.
    Note: if your camera is bison, in the windows directory, there is a folder called "bison" something. so you can download the camera application for bison.
    Jul 20, 2008 | Acer Aspire 5610-4648 Notebook
    Webcam breakdown
    check in the device manager, if your camera is there.
    it's supposed to be under imaging device.
    if it isnot there, it's mean something wrong with your camera, it could be camera cable or camera itself.
    if it is there, it's mean software problem, try to reinstall application software. if you don't have it you can download from www.acerpanam.com
    Mar 22, 2008 | Acer Aspire 5610-4648 Notebook
    Toshiba Satellite A135-S2276 Notebook Logo
    60 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
