Question about ZTE At&t Avail Z990 Touchscreen Android -gsm Black Smartphone
My atnt avail android i stuck on the boot up screen and keeps turning on and back on but never all the way loaded
When i press the power button at the top the att sign pops up and acts like its going to load all the way up but never does then reboots and keeps doing it on its own i need help asap!!!
  • 4 Answers
Bummer, this is called "bootlooping." Pull the battery and keep it out for 10 seconds, put it back in and hold the power, menu and volume up keys until you get into the recovery screen. The touchscreen doesn't work here, you need to use the volume keys to navigate the options and the back arrow key to select them. You can factory reset here, this should fix your software. It will also wipe all your data off the phone, which sucks. Stuff on your SD card will be fine, and hopefully your contacts were backed up with your gmail account.
Posted on Oct 26, 2012
    New Friend:
  • 61 Answers
I would request your to perform the hardreset on the phone by following steps:-
Press and hold the combination of the Power key+ volum up key+ Menu key when the phone is off. When it enters the boot loader mode of teh phone use the volume key to scroll --> select wipe data and factory reset --> select yes and wait till the phone reboots.
Posted on Jan 20, 2013
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
How do I get to the BIOS setup on a android Motorola A 955
Typically Androids don't have a BIOS. But what the do have is a boot loading screen. there are a few different methods to access the boot loading screen for Androids.
First step for all Methods
  1. Method 1: Press and hold the Up direction button on the D-pad of the phone (Up direction button is toward the screen), and press the Power button until the screen lights up.
  2. Method 2: Press and hold the Volume Down button and the Camera button, and press then Power button until the screen lights up.
  3. Method 3: Press and hold the Volume Down button, and press then Power button until the screen lights up.
But if you are still insisting on a Bios you can download a Bios emulator off Google Play Store
Hope this helps
Dec 22, 2014 | Cell Phones
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
I bought the tablet off of face book yard sale and
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
or try this link out.
android man on his back with red triangle on his chest Google Search
Dec 15, 2017 | Tablets & eReaders
How do i get to the BIOS on a craig 7" netbook clp218?
I have no idea about these craig things which are Android machines, Try this.
Cannot be worse than you got.
How to do a hard reset using external keys? If your tablet is completely locked up and you cannot access the menu functions, use the following method to perform a hard reset using external keys on your tablet:
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
If it doesn't work try search engines for 'Android tablet hard reset'
Sep 10, 2014 | Computers & Internet
What does it mean when android robot is laying on its back
I am giving you an example with an Motorola Tablet. I'd try clearing your cache partition, you can get to the android recovery with your buttons.
As you're going through the options don't do the factory data reset, look for wipe cache partition then follow the instructions to reboot.
Hope this helps!!! Let me know if you need more help
-Nadeem
Dec 25, 2012 | Ematic 7" eglide Pro Tablet
ZTE At&t Avail Z990 Touchscreen Android -gsm Black Smartphone Logo
354 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
