Question about Matsonic MS9158E+ Motherboard
Pc not boting
It shows ntdlr dll missing. when i boot it with windows cd it dosent boot
  • joecoolvette
    joecoolvette Oct 27, 2012
    The files that are missing are critical Windows files. BOOT files. You need to install the Windows CD again, and choose Repair. (Non-Destructive Installation )  IF, it isn't the Windows CD that belongs to the computer it isn't going to work, UNLESS it is a fresh, new GENUINE copy you obtained. Also check to see if the disk is dirty, and/or the laser optical eye in the optical drive.
  • Matsonic Master
  • 3,606 Answers
You need to run the Windows XP recovery console.. Should be on the XP CD..
Configure your BIOS to boot order your CD ROM drive first.. Have the disk in
the CD drive when you reboot, and choose the Recovery console from the menu..
Once it's loaded, and it asks which Windows Installation you would like to
access, choose the right one (usually # 1), then enter the ADMINISTRATOR
password then you'll be at a command prompt... There, you can view the
directory of the C: and the C:\windows folders, as well as the contents of
the XP disk in your CD drive.. you'll need to copy the "NTLDR.dll" file to
the Root directory, usually C:\ .. Reboot, if no succes you have to reinstall windows again.
Please make a copy of the 25 digit code.
Here you can download all the drivers
http://members.driverguide.com/driver/detail.php?driverid=181558&si=3c37af981ca3324988fee5ce29463212&sp=1
The file needs to be unziped
Good luck
Posted on Oct 27, 2012
In My PC Error Shows NTDLR File Is Missing,How To
Method:1
1.Make the first boot device as CD-ROM
2.Boot the system with windows(operating system cd)
3.go the first repair(r) option
4.once u got the command prompt change you directory to X:/i386
copy x;/i386/ntldr c:
copy x:/i386/ntdetect.com c:
note:x:(cdrom) drive may change
and then reboot the system.
method 2;
boot with the operating cd and go the second repair option and repair the operating system
Dec 02, 2009 | Gateway 500GR PC Desktop
Tip
Fixing HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Type bootcfg /list to show the current entries in the BOOT.INI file
  5. Type bootcfg /rebuild to repair it
  6. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Error message NTLDR missing on formatted hard drive
You need to either reinstall windows, or take the hard drive out, hook it up as a spare drive to a working computer and copy NTDLR to the root of the laptop hard drive. It would be much easier to reinstall windows. You can always use the recovery portion of Windows, but if I were you I would just do a format and reinstall. NTDLR is just a startup file for Windows XP, that does not mean your hard drive is gone or anything. Please don't forget to rate!..Thanks
Jul 14, 2009 | Compaq Evo D500 PC Desktop
Ntdlr missing and lost bios password
Hi dear do one thing .. Repair your XP.. in set your XP cd .. boot from CD there option call repair
Thank you
Imran
Pls give you me a rank as possible
Apr 16, 2009 | Acer Aspire 5100 Notebook
Fujitsu Siemens Scenic T on windows 2000 Pro SP4
to fix it:
u should boot up with windows 2000 cd
go to repair windows then go recovery console from cd rom
now u'r in dos mode:
if u'r cd rom drive is d: and u'r hard disk is c:
just type this:
c:\copy d:\i386\ntldr
it's ntldr not ntdlr
then type:
c:\exit
u'r pc will restart and everything should work fine.
Hope this Helps. Regards Khushroo
Mar 09, 2009 | Fujitsu Siemens Computers & Internet
Hal.dll file missing, can't boot from xp disc as error states hard drive cannot be detected
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Nov 15, 2008 | Computers & Internet
Install missing dll file
Dear
If u have missing .dll file (download from web)
copy .dll file to c:\windows\system32
go to run and type (if ur dll file is abc.dll)
regsvr32 abc.dll
and press enter n ok
Oct 19, 2008 | Computers & Internet
Windows>\system32\hal.dll. corrupt
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
NTDLR IS MISSING ERROR
http://www.computerhope.com/issues/ch000465.htm
Dec 27, 2007 | Gateway 500GR PC Desktop
Missing or corrupt \system32\hal.dll
You didn't need to replace the hard drive if there is a missing NTLDR file, it just means that the boot sector is missing or corrupt. You can fix it by putting in your WinXP CD, and choosing REPAIR.(This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Mar 28, 2007 | Western Digital Scorpio WD800UE 80 GB Hard...
Matsonic MS9158E+ Motherboard Logo
113 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
