Question about Ladybug 2350 Tekno Steam Cleaner
Ladybug 2350 It starts to heat up and after a few minutes the malfunction call service light comes on.
What do ladybugs eat and drink. Hope you can tell me XD
They actually eat other bugs like aphids.
Feb 27, 2014 | Vacuums
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
We have a Hoover WindTtunnel, Model U6435-920, which shuts off after just a few minutes of vacuuming. We've been told that it has a heat sensor that is malfunctioning, but that it can be bypassed. Is...
What you have is a bad thermal fuse. The fuse is located on a motor wire inside the motor compartment,( part # 28382093, msrp $ 6.59). A good deal of disassembly is required to access this part. Bypassing is NOT recommended.
Aug 16, 2011 | Hoover Windtunnel Supreme U5280-900...
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
Keeps stopping.
your battery isn't holding a charge ,buy a new battery
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
No power to the motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=601650
Posted by jdw121 on May 16, 2008
When I turn the machine on (both red and black switches) the red heat light goes on but the motor does not. If I leave the unit unplugged for a half hour or more, the unit will turn on. If I turn it off and then try a few seconds or minutes, the motor will not turn on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a thermal switch problem – when the machine gets too hot it will shut off to protect the machine until it cools off and then it will re-start or if it gets hot or plugged. The one light could be for the heater and the other could be for the motor, but it is a good idea to check with the customer service dept @ Bissell to see if they have a better solution and also check in the trouble shooting part of the owner’s manual. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Embedded Dirt Finder green light won't come back on - stays red
The dirt sensor is a motion detector. After it gets dirty it will either stay red or stay green. You can have the vacuum serviced at your local vac shop and possibly get this fixed. Sometimes they are as good as new and sometimes they are not repairable. It will not effect anything else though.
Jun 09, 2017 | Hoover U6634-900 WindTunnel Bagless...
Ladybug 2350 Tekno Steam Cleaner Logo
49 people viewed this question
Top Ladybug Vacuums Experts
JoeVacs
Are you a Ladybug Vacuum Expert? Answer questions, earn points and help others
