Question about Nikon Coolpix L1 Digital Camera
How to activate self timer
Happy New Year, How do I activate the self timer function on the L1.
Thanks
  • boomboom321 Jan 03, 2009
    Well, Sean, I feel so dumb! LOL It couldn't have been any easier, with your help and the Fixya site. Thanks for putting an end to my frustration!
  • 37 Answers
Just to the left of the [OK] button, there is a button with a symbol that sort of looks like a clock with one hand... that is the timer button. Press that -- you should see a timer symbol appear on your display. After you press the shutter button, the picture will be taken in about 10 seconds.
Posted on Jan 03, 2009
Intel self adjusting in-wall timer
Reset timer by holding down on-off button then press and release small round reset button. Then release on-off button. Display should flash 12:00
This timer uses CR2 battery.
If functionality is not restored after new battery and reset, then timer has probably gone bad?
http://waterheatertimer.org/ST01C-program.html
ST01 timer has 1 year warranty from intermatic.com
gene
h
Jul 03, 2014 | Intermatic Inc. ST01C Digital In-Wall...
Timer display says "Lo Battery". I put two new
Intermatic timers might require reset-and-reprogram after battery replacement.
To reset, hold down on-off button and push reset button once.
Keep holding on-off button until display changes.
Release on-off button, and display should blink 12:00
Try cleaning battery carriage contacts with alcohol and make sure battery polarity is correct.
If functionality is not restored, then replace timer.
Intermatic EJ500 comes with 1 year limited warranty and is rated for incandescent light bulbs only.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 08, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Re Intermatic ST01C White Self Adjusting Wall Switch Timer Pgm indicates "SNST". I can't change it?
Last ditch troubleshoot for ST01C is to change CR2 battery and then reset timer.
Battery is inside compartment located below programming buttons.
How to reset: Hold down on-off button. Push reset momentarily. Keep holding down on-off until display shows INIT. Release on-off button and 12:00 is flashing. Reprogram timer.
If functionality is not restored, then timer is bad.
ST01C has 1 year limited warranty.
Heavier duty Ei600 is same timer, but has 5-year limited warranty.
Open following links for ST01C and Ei600 wiring illustrations, battery illustration, and programming, manuals and resources:
Aug 01, 2011 | Intermatic & Self-Adjusting Wall Switch...
Canon EOS 5D Mark II whrer is the selftimer botton
Self timer function is mentioned on page-86 of manual.
Below image is part of user manual that will help you to turn on self timer.
Thanks.
Jun 16, 2010 | Canon EOS 5D Mark II Digital Camera
New GE Profile dryer DPSE810EG7WT does not work. I wired exactly as old dryer. L1 L2 and neutral. The timer comes on but the machine does nothing! Thanks, Roger
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Apr 26, 2010 | GE DCVH515GF Gas Dryer
Does it have a timer for self-portraits?
Yes, it has self timer function. Please check button that has clock symbol, press it to select self timer, press shutter button to activate it.
Hope this ifno will help you.
Thanks.
Dec 04, 2009 | Sony Cyber-shot DSC-W180 Digital Camera
I can't find the self timer function on my nikon coolpix 8800. where is it. thanks
Press the self-timer button (marked with a one-handed clock) once for ten-second delay, twice for three-second delay, three times to cancel timer. To start the self-timer, press the shutter release button.
Nov 15, 2009 | Nikon Coolpix 8800 Digital Camera
Self timer set up
1. Secure the camera to a tripod or place it on a stable surface.
2. Rotate the mode dial to [S], [P], [PICT], [AV], or [M]
3. Press the Power button turn on the Camera.
4. Press arrow [>] .
5. Use up arrow or down arrow to select the desired self-timer mode.
6. Compose your scene and press the shutter button.
  • The self-timer function is activated.
  • The photograph is then taken after the preset time.
  • To cancel the self-timer at any time, press the shutter button.
After one shot is taken, the self-timer mode is turned off.
If you wish to take another image using the self-timer, repeat these steps.
Mar 19, 2009 | Pentax Optio 60 Digital Camera
I have a Samsung d73 Digimax and would like to know whether this has a self-timer function and if so, how does one use it?
No problem! Like all Samsung Digimax cameras, the self-timer is located by pressing the round navigation key once to the right/East/3 o'clock (it has a picture of a clock engraved on it). Pressing once gives a 10 second timer, twice gives a 25 second timer and the third press gives a multiple-burst self-timer whilst the fourth press will de-activate all timer functions. After selecting the appropriate self timer, depress the shutter button to activate.
I hope that this helps!
Dec 05, 2008 | Samsung Digimax S600 Digital Camera
Self Timer Activation
The instruction manual is quite poor. Once you have decided which option you would like (2 or 10 seconds) you must go back to the main menu to select which drive mode you would like. Single is default. From single, you can select self-timer, which will activate it for your next shot. The drive mode will always reset back to single after every shot so you'll need to set this up for every self-timed shot.
Happy shooting!
Jan 03, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Nikon Coolpix L1 Digital Camera Logo
201 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
