Question about Behringer Xenyx 1204fx
Can't hear effects thru headphones on my 1204fx xenyx mixer
Effects don't work thru Control Room Out or Phones Out
  • 9 Answers
SOURCE: effects button not working!!!!
Most likely the fuse for the effects circuit has blown, which happens sometimes on mixers with built in effects.
You'll have to open the mixer as the fuse will be inside the mixer on a circuit board (look around inside where the effects part of the mixer is) replace it with an identically rated working fuse and you should be done.
Posted on May 28, 2009
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
SOURCE: Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Posted on Mar 24, 2010
  • 5603 Answers
SOURCE: I have a Behringer SL2442FX-Pro
First thing to check is the power supply voltages. I have seen a Behringer effect module that had low 5 volts and it continually reset itself.
Schematics: http://elektrotanya.com/behringer_sl2442.pdf/download.html
Typical Behringer mixer should have same DSP as yours and similar or identical power supply
http://elektrotanya.com/behringer_ub1204fx_pro.pdf/download.html
Posted on Dec 30, 2010
  • 5603 Answers
SOURCE: Beringer Xenyx 1204fx emits a
This is likely a problem with the FX in the unit or the power to it. Does the FX display act correctly? Check that the headphone source "Main Mix" is the ONLY button down for the headphones. If not, make it so. If the clicking is still there, try the headphones in the aux send jacks... see if EITHER left or right can hear the clicking. Back in the phone jack, scan across the SOLO channel buttons down one at a time. Is there clicking? If not, the problem involves the mixing buss or further down the line. Make sure the SOLO buttons at the FX Aux sends are up.
What effect does the MODE button have in SOLO and in PFL? Is the SOLO LED off? Is the number in the FX window SOLIDLY on and not flashing?
Posted on Apr 05, 2011
Testimonial: "Couldn't Fix problem using solution. Could not reproduce problem. I don't know if it is still there or not. Very insightful. Very quick response."
Xenyx mixer effects
USERNAME OR PASSWORD WANT ME
Dec 17, 2013 | Music
How to connect Echo/delay/repeat to mixer that enable me to setup/control all 12 channels on my mixer
You have built in effects that you can use - if you're trying to connect off board effects as well you need to use one of the aux send/returns.
Oct 23, 2013 | Behringer XENYX 2442FX Mixer
No effects output xenxy 1204fx
Likely needs the DSP board replaced. It is the small board held on by 2 screws(if I remember correctly) and is easily replaced. I think retail cost is about $30 and can be ordered directly from Behringer.
Aug 03, 2013 | Behringer Xenyx 1204fx
How to get efx to work
You are aware that there are no built in effects, correct? Are you connecting an off board effects unit and having problems with that? You should be connecting the effects send on this mixer to the input of the effects unit - then the output of the effects unit to the effects return on the mixer. With the effects send control on the appropriate channel turned up, you should see signal hitting the effects unit. You'll need to adjust the effects return on the mixer to hear the effects signal included in your mixer output.
Aug 05, 2012 | Peavey PV6 Mixer
The mute button cuts the main audio but the effects audio is still heard. What to do?
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
Mar 25, 2012 | Mackie 1202vlz3 12 Channel Mixer
I've connect my sampler to the mixer. In the RCA "send" and it won't play through my speakers. I can only hear it through the headphones. What could be the problem? I'm using Numark...
You would NOT connect an audio signal to the "send" jacks... those are OUTPUTS... In doing so you are driving signal backward enough to get to the headphones. Sends and returns are NORMALLY used on a mixer for external effects. You should either be using a LINE input jack or one for "tape input".
Sep 10, 2011 | Roland Sp404sx Portable Sampler Wdsp...
Best way to connect 2 1204FX mixers together
Try running the tape out of the slave to the tape in of the master unit. This us haywire, but should work. Use a stereo RCA cable.
Aug 08, 2011 | Behringer Xenyx 1204fx
Beringer Xenyx 1204fx emits a clicking sound... Sounds like a Geiger Counter for radiation in my headphones. I have used the same sound mixer in the same configurations for 3 weeks. Now I've had it...
Apr 05, 2011 | Behringer Xenyx 1204fx
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Xenyx 1204fx Logo
83 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
