Question about Canon ZR200 Mini DV Digital Camcorder
When i play the video tape, the picture is like pieces of puzzle
I had the issue of the tape constantly ejecting and followed the tip of smacking it twice. That worked! But now, it the image on the lcd and on computer (if plugged in) looks like puzzle pieces. Some of the pieces are in brown/gray so you can't see parts of the picture at all. Any ideas?
That kind of happened to me, except there were gray horizontal bars going across my screen. I could only see half of what I was watching. Turns out, I just kept playing the tape and they magically went away. crazy but true. Now the only thing I need help with is getting the tape in it, as the camera won't take any tapes.
Posted on Jan 21, 2009
Constant ejecting
This is already an issue with the hardware. There is a rubber bond inside the cassette that is no longer intact and needs to be replaced. Possible cause by repetition of single and old cassette tape and improper tape position.
Apr 06, 2010 | Video Cameras
Blue screen showing error code c:31:23
This may seem silly, but it worked for me. I found this on discussion forum. Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. The mine works too!
Sep 11, 2009 | Sony Handycam DCR-PC115 Mini DV Digital...
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Error C:31:42
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Jun 02, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
C 31:20 is my special message
Feb 11, 2008 | Sony Handycam CCD-TRV608 Camcorder
Warning indicator C:32:00/C:32:11
I had the same problem (error c:32:00, beeps and tape would not eject. Cassette was halfway ejected) on my Sony CCD-TR416. I found the fix here:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html
To summarize: remove the battery, unplug from the wall and smack the **** outta the bottom of the camera. It worked for me. It looks like my problem was that the tape had started coming out of the cassette body and caused a jam.
Feb 05, 2008 | Sony Handycam CCD-TRV43 Camcorder
Not play tape
Dec 18, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Sont DCR TRV16
Smack it!!
And have a look at www.camerahacker.com
Aug 14, 2007 | Sony Handycam DCR-TRV16E Mini DV Digital...
Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
May 08, 2007 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
184 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
