BP6000 seikosha precision i have replaced print head and crriage cable it cutting caracters at the bottom
Poligom motor c500
polygon motor are located inside the print head there are 4 prints heads for the C500. replace the the print head and conducted required check
mite try this site for part as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
Seiko precision BP-9000 driver windows 7 64bit
hi, need to check Seikosha BP-9000plus can support windows 7 64bit or windows 10 or not? and where can get the driver.
Appreciate. thanks!
Oct 19, 2013 | Seiko Office Equipment & Supplies
I've got a Seikosha SP2400 printer which is used by multiple users. However when connected to a pc this printer is extremely slow. When running self test prints it prints at the correct speed. I've...
hello
http://www.seiko-precision.de/en/site/PRODUCTprotokolldrucker/contentfcmsv43fd4b22cd4c2c/product.xml
select above link, go to bottom of that URL and download manual
i reviewed all 148 pages.. there is nothing i could find anything about adjusting speed
this printer , is about 10 years old or more.
sorry i could not be more help
regards.
Nov 05, 2010 | Computers & Internet
Blank white 'line' on printed output
Some of the brother printer use a toner cartridge that does not have a drum, have u replaced the drum recently, or does the toner cartridge have it installed? If it has a seperate crriage for the drum, let me know.
Dec 11, 2008 | Brother HL 5140 Laser Printer
TallyT2240 Dot Matrix only prints the middle part of the caracters
It sounds like you have one of two problems;
1) The ribbon cartrige it warn out or damaged, leading to no ink in a particular area.
More likely
2) The print head is damaged or warn out or is not connected correctly to the pritner. The print head may need to be reseated or if this does not fix the problem the print head may need to be replaced.
Oct 28, 2008 | TallyGenicom TallyT2240 Dot Matrix...
Unusual character where special character or underline is given
If you have a spare USB cable around the house, try that first and see if the cable was bad.
Aug 21, 2008 | HP DeskJet 640c InkJet Printer
Hp 9800 print alignnment
Reset your margins in the printer settings, it sounds like it is cutting off the edges according to margins. Post agian if no go.
Aug 02, 2007 | HP DeskJet 9800 InkJet Printer
46 people viewed this question
k24674
jasbo
jasbo
