Question about ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard
Is there are realtek audio driver for asus p5kpl cm motherboard???
    New Friend:
Hello there.
I have a problem with the sound card on my asus P5KPL.
Draw drivers from asus, but did not hear the sound.
Can you help me pls
Thanks in advance.
Posted on Apr 09, 2013
  • joecoolvette
    joecoolvette Apr 10, 2013
    What Windows operating system, and what procedure did you use? Did you download AND install? Don't just say yes, I would like to know what procedure You used. Post as a Comment. Regards, joecoolvette
  • ASUS Master
  • 3,606 Answers
Hello you can download the driver here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLCM/#download
First select your windows
Select audio and select global for download
Please unzip the file before installation
Good luck
Posted on Oct 27, 2012
  • ASUS Master
  • 5,660 Answers
Let's go to Asus Support, and see;
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLCM/#specifications
Audio -> VIA VT1708B / 8-Channel High Definition Audio CODEC
It's a VIA audio chipset.
The answer is NO
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
Driver. Sort for Device driver
Driver: A small piece of software that allows the Operating System to communicate with a device.
The device is the audio chipset.
You didn't state what O/S you are using.
Drivers are written for devices by the device manufacturer, when specifically referring to an audio chipset.
What would make you think it should have a Realtek audio chipset?
Post back in a Comment.
Regards,
joecoolvette
SOURCE: ASUS P5KPL-CM Bios Problem with Core2Duo 2.8 Ghz Processor.
I recommend going to this site and getting the latest Bios for the board.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I don't know your expertise with computers but it will require you downloading their Bios boot disk utility and creating a boot disk. then copy the Bios file to the same disk. When you boot it up it will guide you through the Bios flash process.
Be aware that you can completely kill the Bios if it has a problem during the flashing so only do it if you are positive you can get through it.
Alternately if you can push the F1 and get into the OS the Motherboard utility disk should have an updater you can use from inside windows.
Posted on May 04, 2009
map9966
  • 2351 Answers
SOURCE: i am unable to install sm bus driver on my ASUS P5KPL-CM
Go to this Asus Global web site;
http://www.asus.com/product.aspx?P_ID=6nnVb6RBxd7PhGmt&content=download
Click the drop-down button & click on your operating system.
The SM-Bus controller is installed with-in the chip-set driver.
Intel(R) P45/ICH10R Chipset Software Installation Utility WHQL V9.0.0.1009 for Windows XP/Vista & 64bit XP/Vista.
Normally this is installed after a fresh install of windows. However if windows is giving you trouble you can re-install the chip-set driver utility. Than check windows for any updates.
Mike
Posted on Jun 18, 2009
chamboard
  • 557 Answers
SOURCE: video drivers for windows 2003 in ASUS p5kpl-cm G31
hello: look for asustek or google for it
there you find drivers
Posted on Nov 01, 2009
tonmoy1001
  • 91 Answers
SOURCE: ASUS P%KPL-VM audio problem
plz go to control panel and add hardware option.then search which drivers are working properly..
if you find your audio drivers not working..plz remove it first and then restore your system..and install it again
Posted on Feb 07, 2010
juriksson
  • 149 Answers
SOURCE: Hi i use asus P5KPL-AM
Hi
Check the BIOS settings . Perhaps embedded audio is disabled
Check in Device Manager correct driver installation
Check correct auto-detection connection speakers. May need to manually adjust
Posted on Aug 07, 2010
How can i install the audio for my asus p5kpl-am epu motherboard for free? please help me.
hi
go to following link you will find your audio drivers for free
http://asus.mydriversdownload.com/asus-drivers/Asus-Socket775-P5KPL-AM-EPU-AUDIO-VIA-Audio-Driver-V6.0.1.7100-for-Vista-32bit_13065.html
Oct 18, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Feb 07, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Video drivers for windows 2003 in ASUS p5kpl-cm G31
Nov 01, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I want asus motherboard driver how can i dowanload..tell me...? asusmother board p5kpl-cm i want all driver...
  1. Go here: http://www.asus.com/
  2. Select your country
  3. Click on Services, Support
  4. Browse to the Download section
  5. Input your motherboard model to display available drivers.
Sep 11, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
How to insatall sound driver of p5kpl-vm/psit is not able to install from its driver cd
I am Not Install The Audio Drive Software
So Plz Send This Software PI945GCM Audio Drive Software
Jun 25, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Drivers Pack For Windows Vista 7 is required
I will give you a alternate and easy way for your problem.Just download this software named driver magician and install it.It will search for the drivers for all your hardwares and components that doesnt have proper drivers and will download it.It will make your problem easy
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
May 17, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard Logo
237 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
