WHY IS THAT MY SHARP ES-S1251F WASHING MACHINE DOES NOT WORK ALL OF A SUDDEN? IT HAS NO POWER AT ALL.
SOURCE: My instruction manual of Sharp ES-S701X washing
I have a copy, can scan and email to you,let me know, kumanan1950@yahoo.com
Posted on Mar 08, 2010
  • 59 Answers
SOURCE: hello sir ineed assistence with
yes but what is the problem?
Posted on Aug 30, 2010
  • 6277 Answers
SOURCE: I need the manual for
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 30, 2011
SOURCE: sharp model ES-710PF WASHING MACHINE,
HELLO MY PROBLEM IS THE WATER OVERFLOWING THE WATER IS FULL AND E1 ERROR ALARM
Posted on Jun 20, 2011
  • 6277 Answers
SOURCE: MY Sharp ES-S601X washing machine
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Jul 10, 2011
Testimonial: "Thanks a lot. It helped and worked."
My sharp is destroyed? it isn't work
go to a store were they sale the same machine with English instructions and copy the information or take a picture..
Feb 07, 2018 | Washing Machines
Sharp es 950 top load washing machine as on same time beeping and showing e2
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to washing machines are given.
Dec 07, 2015 | Washing Machines
My sharp washing machine (es-q75ew-g) can not fill & wash its just draining?
the drain line is to low if the water is emotying as it is filling, raise the drain hose above the washer to 48 inches and I bet it will stop draining and start operating.
Mar 29, 2014 | Washing Machines
Sharp washing machine es s701x
What is your problem ? Not washing, making noises, no spinning, no draining, shaking, what ?
Aug 25, 2013 | Maytag Atlantis MAV9501E Top Load Washer
Sharp washing machine,ES-AG950 hangs during the spin cysle.
Sounds like its tripping the drum vibration sensor or a temp limit sensor on your motor.
Apr 09, 2013 | Washing Machines
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Jan 20, 2013 | Kenmore Washing Machines
My Sharp ES-A50S washing machine won't spin dry. the alarm warning that the lid is open always sounds off even though I closed it already. what should I do????
ok your problem is due to some problem with lid sometimes a heavy wait on lid of dry drum makes it settings wrong alignment is not correct plz call the mechanic there it will fix
Sep 14, 2009 | Washing Machines
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
