Question about KitchenAid KUDC25CH Dishwasher
How do I take apart the water inlet valve on a kitchenaid dishwasher model kudi25ch to replace the gasket
jsrock516
  • 5911 Answers
SOURCE: noisy kitchenaid dishwasher during filling
Fill valve replacement should be fairly simple. Most dishwashers are constructed in a similar manner, so although these steps are generic, it should lead you in the right direction: 1. Remove the lower kick panel right below the dishwasher door. The fill valve should be located in the front of the dishwasher on the left hand side. 2. Turn off the water supply line. 3. Turn off the circuit breaker to the dishwasher or unplug the unit as necessary to secure power. 4. Carefully remove the two wire connectors going to the fill valve solenoid. These wires are delicate, so be careful with them. 5. Leave the fill valve attached to the mounting plate in order to loosen the supply line. Once you have the supply line loosened you can remove the valve from the mounting plate by removing either one or two screws. 6. With the supply line disconnected, wires removed and the valve removed from the mounting plate, you can now remove the secondary water line that goes into the wash tub. It is usually behind the valve and easier to access if you can pull the valve out far enough the reach it. 7. Make sure you put teflon on all your threads BEFORE you re-install. 8. Installation is in the reverse of what I just explained to you. You should not have to remove the dishwasher from under the counter, but you can if it makes access easier. It's that easy. Just make sure you check your water lines for leaks BEFORE re-installing the kick plate. And, make sure you reconnect the wires properly. Good luck. I hope this helps you.
Posted on Jul 10, 2007
  • 71 Answers
SOURCE: no water enters dishwasher (Kitchen Aid KUDS25SHBL1)
usually 120 volts
Posted on Dec 12, 2008
SOURCE: Kitchenaid dishwasher leaking from door
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Posted on Jul 12, 2009
  • 864 Answers
SOURCE: Kitchenaid Dishwasher makes jack hammer sound when filling
Check the power to the valve actuator with a meter. If the power is not fluctuation (causing the valve to open and close quickly) then the problem is likely "water hammer" in the piping leading to the DW. Water hammer occurs when a fast flow of water turns a corner in the piping. The solution is too find where the pipe is vibrating and add support. Another way to eliminate water hammer is to install a shock tube on the pipe. It is filled with air and acts as a shock absorber when the water hammers. They are available at Home Depot, Lowes, plumbing supply places, etc. Another way to make a shock absorber is to install a tee in a horizontal part of the pipe with an 18 inch+ piece of pipe installed vertically and capped at the top. Air gets trapped in the vertical pipe and cushions the vibration. You might be able to do this in the space behind the DW before the pipe connects to the DW. The shock tube is smaller and does not have to be vertical so if space is an issue that may be the way to go.
Posted on Sep 18, 2009
  • 760 Answers
SOURCE: I have a KitchenAid dishwasher KUDC25CHBT1 that is
Ok if it only leaks while filling, and not while running, it is probably the fill hose that goes from the fill valve to the washer. This hose can be accessed by removing the lower kick plate (2-4 screws) look on left side you'll see your incoming copper tubing (or hose) and a larger hose with clamps on each end It may have vibrated a hole in it or be leaking at clamp. Another possibility is the fill valve itself is cracked and leaking only when the valve is on.
Posted on Jul 17, 2010
Testimonial: "I am hopeful you can provide more details now that I have better described where it is leaking. Thanks for your help so far!"
Kitchenaid kuddo1dppa
test this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 22, 2013 | Dishwashers
No water will enter the dishwasher, There is no problem with the water supply or the supply line. The water flows from the supply line to the dishwasher connector but does not enter the dishwasher.
The water-inlet valve lets water enter the machine. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Nov 23, 2010 | KitchenAid Dishwashers
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
Dishwasher makes grinding noise during wash cycle (after pre-wash). noise persists for 15-20 minutes. It seems as though the inlet valve doesn't open during this phase of the cycle. adding water to the...
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Nov 19, 2009 | KitchenAid Dishwashers
The dishwasher leaks.
Check the following in the same order as i mentioned :-
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | KitchenAid 24 in. KUDG25SH Built-in...
Danby DDW396: pump leaks when in use.
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 11, 2009 | Danby 22 in. DDW396 Free-standing...
Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Leaking Dishwasher Help!
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Dec 12, 2006 | KitchenAid 24 in. KUDI02FRSS Stainless...
Open Questions:
See all KitchenAid KUDC25CH Dishwasher Questions
KitchenAid KUDC25CH Dishwasher Logo
195 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
