Question about Daewoo DW500M Top Load Washer
Dwf 200mp top loading problem spin not working display lE what is?
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
LE error after full cycle toward end of wash it comes up with an error. not sure if it LE or upside down F E? Anyone have this prob?
LE toward the end of cycle probably means you had a bulky load which you tried to spin out at the high spin speed setting. Use a low spin speed with bulky loads. For this load now, just put power on and without selecting a cycle, push the spin speed selector button until a low speed comes up (should be about a 14 minute display) then push start to do a pump and spin only cycle.
Sep 25, 2010 | LG WM2277H Front Load Washer
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
Daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
May 23, 2008 | Washing Machines
Daewoo DW500M Top Load Washer Logo
32 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
