Question about Harman Kardon HK695 Computer Speakers
Harman Kardon Elegant 2.1 speakers problem
I was playing a music on my pc with a very loud volume when my speakers suddenly went off.The led lights were on but there was no sound coming from the speakers.I tried another speaker on the same pc and it worked, but this one doesn't.I also turned the knobs(bass, treble and surround) several times and even the volume.But nothing works!There is still no sound from my speakers.Please help!!!!!!!!
    Genius:
  • 2,985 Answers
'Sounds' like you have overwhelmed the cone and split it or a solder joint has come adrift Don't know about repair or replacement -Check makers website.
Posted on May 13, 2007
Esquire Wireless shuts off during play
Think I might just have discovered the issue here. I had the same problem but didn't realize that the volume was maxed on the unit (as I was controlling it through the phone). As soon I brought the volume down on the unit the problem went away.
Apr 13, 2014 | Harman Kardon Audio Players & Recorders
Older Harman Kardon computer speakers have loud hum
The hum (50 or 60 Hz) is caused by the AC power getting into the entry point of the amplifier. Either the filtering capacitors from the powersource of the speakers have dried up - replace them - or there is a short in the cables.
There is another possibility: if you have kicked the subwoofer  box its transformer might have slipped from its fixings and now is touching the subwoofer speaker frame.
The only way to find which is to open the cases.
Nov 28, 2009 | Harman Kardon HK695 Computer Speakers
Low sound coming from soundsticks II
On the right stick, there are two metal pieces at the bottom of the stick. The right one is + for volume up, and the left is - for volume down.
Press the + one a few times with your finger as they are touch activated. Be careful though, as it can get loud very quickly. Play some music and set the computer volume to about half way. Then press the + speaker on the right hand side until you are happy with the volume.
Hope this helps,
Nathan.
Apr 08, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 22, 2008 | Harman Kardon Go + Play Portable Speaker...
Stuttering and the sound breaks
Sounds like the controls have dust in them. Blow the controls with dust cleaner.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
May 19, 2008 | Harman Kardon SoundSticks II Computer...
Speakers no sound
see the spk wire are properly conncted. bye
Sep 22, 2007 | Harman Kardon SoundSticks Computer...
No sound
I've had my speakers for about a year now and all of a sudden they just stopped playing music/sound. I can still hear that 'fuzz' if I put either speaker up to my ear. Everything lights up properly but nothing is being played.
Sep 20, 2007 | Harman Kardon SoundSticks Computer...
Chances are you have wrecked the cone and movement with the overly high input. Nor repairable if this is the case. Check out the makers website for more tech info
May 13, 2007 | Harman Kardon HK695 Computer Speakers
Harman Kardon HK695 Computer Speakers Logo
461 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
