I want to use external casing with my desktop hard disk ,can i use it ,is it safe to use .?,does its corrupt data is used with this type of method,how much speed i will receive ... and tell me extra precaution and care its requires
  • gaurav Oct 27, 2012
    thanks you Chris sir for your help.just one more thing , how much speed it have and does it corrupt data by quickly removing it form usb without the option "safely remove drive"
    and is it possible to read data again by removing corrupted data drive errors
  • 32,281 Answers
These are easy to use, just like a USB memory stick. No special requirements are needed.
If your hard drive is a SATA or IDE type you need to purchase an USB 2 hard drive adapter case that matches your hard drive.
Posted on Oct 27, 2012
  • Chris Hingee
    Chris Hingee Oct 29, 2012
    Any device that is plugged into the USB port need to be disconnected correctly using the "Safe Remove option" otherwise data can be corrupted because data could be still written to the USB device as you pull the device out of the USB port. In this case you will have no hope in getting your data as it will be incomplete.
SOURCE: system not detecting hard disk
how to recover data from corrupted external hard disk???????
Posted on Jul 31, 2008
SOURCE: Portable hard disk corrupted
try chkdsk /f <drive>
Posted on Aug 31, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
SOURCE: Zippy USB external hard disk case (2.5
I know this is an old thread, however if it helps any one try this:
Zippys power supply failed for me also. The problem here is your case support USB 2.0 ("A high speed USB device") and your port is only USB 1.1 ("plugged into a non-HI-SPEED usb hub"). This will not give adequate power to the drive. So use a y-cable (http://www.toshibadirect.com/images/ui3/accessories/toshiba-usb-y-cable-ba82010-300.gif) and connect one end to your casing and the two pins at the other end should be connected to two USB ports. (get it at http://www.toshibadirect.com/td/b2c/adet.to?poid=438342).
Another costlier way is to upgrade to USB 2.0 by a card like this http://www.belkin.com/support/download/download.asp?category=1&lang=1&mode=
or even better a USB 3.0 card : http://www.asus.com/product.aspx?P_ID=lGYmelQ8mJvPtYTv
Posted on May 24, 2010
  • 629 Answers
SOURCE: when I connect my seagate expansion external hard
either an issue with the hard disk, or with your system. Make sure the hard disk has power on it and if you can, it would help to test it on another computer to confirm if it works. If you have ruled out the possibility that it is the hard disk, next is review if the hard disk has system requirements you need to meet. If the requirements are met by your XP SP2 machine, you may try updating the computer's system software/chipset drivers and a BIOS update may also be necessary.
Posted on Aug 29, 2010
I have a Samsung 3g 2tb harddisk and it makes strange noises. sometimes it doesnt work and a my pc freezed.
Here is what you need to know about hard drives.......
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
I hope this is helpful..........
Good luck.
Mar 07, 2011 | Samsung G3 Station Desktop External Drive...
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Good luck.
on Oct 21, 2010 | Computers & Internet
Wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
Hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
Transcend 500 GB External HDD is detected but doesnt show the data in it.
Your external HDD may be corrupted. Recover the data before you use it.
First things first: STOP using the external hard dive that you want to recover data from in case you may quite possibly ruin your chances of data recovery.
Then Recommend you have a try of Wondershare Data Recovery, a data recovery program with both Windows and Mac versions provided. It should help you. Get the related versions here,
Data Recovery Windows (for Windows)
Data Recovery Mac (for Apple Mac OS)
Remember - Do NOT try & write anything back to your hard drive until you can recover your data safely!
Nov 20, 2010 | Transcend StoreJet 25 Mobile 500GB USB 20...
My problem is with windows I see a page that say
You're seeing that screen because there is something seriously wrong with your setup.  Sorry.  The 4 most likely causes are:
-Windows itself
-Corrupt or missing drivers
-Virus
-Hardware
What to do about it:
The first thing to do is see if the computer will boot up in safe mode.  If it does, then it's probably not hardware & you can sigh with relief because it's not going to cost you that much.
You're probably going to have to reload windows again. Backup first!  If the computer boots up in safe mode, Internet Explorer will still work and hopefully USB will too- this will allow you to backup your data.  If not, you can take the hard disk out; take it to a local computer shop and buy an external hard disk of the same type (IDE or SATA).  If you ask nicely, the man in the computer shop will put your old hard disk in the new external case.  Then you put the NEW hard disk in your computer and install windows on it.  Then you can plug the external hard disk (with your old hard disk in) and you have all your data conveniently accessible.
If the computer will not boot up in safe mode; either windows is royally stuffed; or it's hardware.  There's 3 ways to go here:
1) Do as above and hope it's not hardware because you will have paid for a hard disk you don't need.
2) On another computer, download and burn this boot CD:
http://www.hiren.info/pages/bootcd
...and use the tools therein to assess the state of your computer.  Use the tools with care- it's easily possible to lose data or change something you shouldn't.  If the CD loads up OK and the computer stays on when you're poking around it is *probably* not hardware...or at least not anything critical.
3) Get an expert in.
Obviously you should do this in the cheapest order possinle so:
1) Try booting up in safe mode
2) Try Hiren's boot CD
3) Buy an external hard disk and swap it out
or
3 again) Get a tech in.
Mar 03, 2010 | Dell OptiPlex GX270 PC Desktop
WD external Hard drive 320 GB hangs my computer everytime connect
Try the external hard-drive in some other computer.
If it still causes problems, then it is the external hard-drive, not your laptop, that has the problem.
If the warranty on the external hard-drive is still valid,
exercise the warranty to get a replacement.
If the warranty has expired, you could try to "disassemble" the casing, to remove the "internal" hard-drive that is "inside" the casing.
Then, connect that hard-drive to a desktop computer,
and copy your data to the 'C:' drive (or burn your data to CD/DVD disks), if you can -- it's possible that the "electronics" that convert the USB-interface to the hard-drive interface is the problem, and that your data on the hard-drive is perfectly OK.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hard drive failure in system less than 2 years old!!
Since you are comfortable with working inside your computer, the best thing to do now is to purchase an external enclosure for your type of hard drive, SATA or EIDE.
Alternately you can use a live linux cd, boot up with that, and transfer your data to an external drive.
Once your data is safe, try booting to the Windows cd and attempt a repair installation.
And finally, yes, hard drives can go bad in 2 years or less.
Dec 14, 2008 | Dell Dimension 2400 PC Desktop
Data recovery from corrupt external hard drive
Well, in your case you should format the external drive and then try some so-called data recovery software.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Dec 07, 2007 | Computers & Internet
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
