Question about Axial Syma 9086 Helicopter
I have a double horse 9083 and i cant seem to control it i have adjusted the tail rotor and still nothing.
    Problem Solver:
  • 21 Answers
Hi, Does the tail motor run freely (nothing wrapped around the motor shaft) if so have you adjusted the potentiometer on the circuit board. If niether of these work I would say you have a faulty circuit board.
Regards, Julian.
www.stores.shop.ebay.co.uk/GADGETSNTOYS-UK
Posted on Feb 22, 2009
THE BOTTOM ROTORS DO NOT SPIN
1) test the button for open or faulty. However clean it with contacts cleaner solvent.
2) Resolder any wires from the button by dry join.
3) Tight the wires from rotor and resolder the dry join from rotor and test again.
You must sure that batteries is FULL charged, otherwise put a new ONES HYBRID ALKALINES. VERY IMPORTANT
God bless you
Jan 25, 2013 | Double Horse 9053 Volitation Remote...
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
Just bought the helicopter and have no idea how to set it up as there was no instructions with it
hello,,if you have access to a pc,,,simply go to a search bar,,,like google,,,, and type in,,,,,RC DOUBLE HORSE ,,MODEL 9083,,,HAWK,,,,, MANUAL,,,,,, and you just have several answers pop up,,,,, you can either read form it,,or type it and have your own manual,,,,,,,, or contact company and request a manual,,,,but you will have to wait for that,, let me know how you make out,,,,, as i may be able to help you further,,,i have about 9 small r/c helis,,, JOEL
Aug 22, 2010 | RC Double Horse Model 9083 Hawk Serie Rc...
I have double horse 9083 chopper and its back part is spinning which is making it unbalanced??????????
You should use a screwdriver and check for any damage.If harm is done take to you local store and expain problem.
Mar 24, 2010 | RC Double Horse Model 9083 Hawk Serie Rc...
Leaning left on takeoff
needs to be adjusted in the radio
May 11, 2009 | Axial Syma 9086 Helicopter
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Axial Syma 9086 Helicopter Logo
411 people viewed this question
Top Axial Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Axial Toy Expert? Answer questions, earn points and help others
