Question about EuroTech EWF150 Front Load Washer
Water Temperature is hot on all rinse cycles Water temperature on rinse on all modes is HOT.  Water is hooked up correctly (the delivery folks hooked it up when installing).  Steaming hot - too hot to touch. My clothes are also shrinking and being destroyed. I cannot figure out how to make this stop except to turn off the hot water entirely, but I am afraid I will damage the machine if I do; it doesn't appear to be using any cold water in the rinse.
    Sergeant:
  • 311 Answers
If your gettig hot water on rinse.your fill hoses are not correct.rinse is only cold.switch the hoses.if that dosent solve the problem call for warrenty
Posted on Jan 03, 2009
RE Whirlpool Mod WTW8200YW0 top load, there is always soap left on clothes in the washer no matter type and amount of detergent my wife uses. Any ideas?
Check the water suppl lines to make sure they are not hooked up backwards the rinse cycle uses cold water if the temperature sensor detects hot water it will stop power to the log valve if hooked up correctly then place unit in a rinse cycle to see if rinse valve is opening
Jan 26, 2015 | Whirlpool Washing Machines
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
I have just taken delivery of a Hotpoint Whirlpool washing machine today.Please explain how on a 30 min cycle the water can be warm when it is cold fill only
Sorry but I'm not certain that I understand your question ;-0(
Maybe if I explain- 'cold fill only' means exactly that; the washer has only one hose and is connected to one cold supply to fill and then the washer will heat the water up to the selected temperature of the wash. The description does not mean that it washes in cold water only.
In the case of a hot and cold fill, the washer would open the hot inlet until the correct temperature is reached and then would continue filling to the right level with a mix of hot and cold water whilst maintaining the temperature. Cold is then used for rinses in all cases as far as I am aware, including yours ;-0)
I sincerely hope that I have not totally misunderstood your question. If I have I apologize.
If this has answered you question please consider a 4 thumbs up on our rating.
Thanks and good luck.
John C
Apr 13, 2011 | Hotpoint Washing Machines
I just rehooked up my washer and I only have cold water going to it. It will go for a while and then reads F-20. What do I do?
he F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
This temperature monitoring is something all the newer washers do. Both water valves must be hooked up to water.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Jan 11, 2011 | Whirlpool WFW9400S
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
check to see that the fill lines are not hooked up backwards, hot on cold cold on hot
if not check the temp selectr switch
Apr 26, 2008 | Washing Machines
Rinse cycle temperature
You may have a problem with your Temp Switch or the Sensor Thermistor.  Very easy to check and fix depending on your technical ability.  Both of these parts are connected off the Automatic Temperature Control Board.
Feb 29, 2008 | Frigidaire GLTF1670A Front Load Washer
Water Temperature
you have the water tubes connected wrong way round ie cold to hot and hot to cold - honest. change them over and bet its cured
Apr 20, 2007 | Whirlpool LHW0050PQ Front Load Washer
EuroTech EWF150 Front Load Washer Logo
183 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
