Question about Haier Refrigerators
Haier refrigerator HB21TB
I need to find the name of a part related to evaporation door. it is a little part and on it written 0060218821.
  • 45 Answers
Read the instruction manual from where you buy the product or go to this site www.repairclinic.com
Posted on Oct 26, 2012
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Hi, can u answer me who mad haiere refrigerator?
Haier is actually the name of the company.
The central Haier building is in Qindao, PR China. Haier has headquater is in New York, USA, and an industrial park i Camden, USA. The CEO is Mr Zhang Ruinin. It is safe to say , based on that information, that Haier refrigerator is made by Haier.
Mar 06, 2011 | Refrigerators
Light stays on. It was flashing LL for the lower
the first step is shutting it off for 24 hours with the door open to make sure there is not any ice on the evaporator. next, make sure the door seal is sealing properly. if neither of those are the culprit, you may need a new thermostat.
Nov 06, 2009 | Haier HVZ040ABH5S Stainless Steel Wine...
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Air or gas leaking from freezer in Haier mini fridge
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Jun 06, 2009 | Haier HRT02WNC Compact Refrigerator
Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
Apr 03, 2009 | Haier HSL06WNAWW Compact Refrigerator
Haier compact refrigerator freezin up. Thermostat wire dangiling. Need to know how and where to position wire.
There should be a clip on the back of the evaporator plate with a bit of foil which normally covers the stat wire end which is the sensor.
Mar 05, 2009 | Haier HSB03 Compact Refrigerator
Punched inside panel.
sounds like some one tried to defrost it with an knife. you can order the evaporator thru haier but unless you know how to do sealed system work you will need a qualifed refrigeration company to repair it for you if you provide the part approximate cost in the states is around 300-400 dollars. good luck peyton
Jan 29, 2009 | Haier HVH025A Wine Cooler
Freezer
first off all the cold air comes from the freezer. you need to remove the freezer floor and then the back to make sure the evaporator is not all frozen up with ice. If it is you have a defrost problem. You would need to check the heater the terminator and the defrost timer. If the coils on the evaporator are not iced over and there is only a little frost at the top or none at all either the compressor is not working or there is a leak and the unit is out of gas. You need to check the thigs I just described and go from there.
Jul 25, 2007 | Haier HRF08 Top Freezer Refrigerator
Refrigerators Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
