Question about Blaupunkt Las Vegas CDM147 CD Player
Vegas CDM147 direct wiring.No harnesses pre-ensambled here...
Hi, I have this new device waiting to be installed in my truck. Here are no harnesses and connectors pre-ensambled just to "plug" them; The only solution I have is to use a soldering gun to wire al the stuff directly to the pins in the rear panel of the equipe, but I don't have the pins identificated.
So this is what I need to know: Wich pin goes to wich cable? (ground, speakers rear/front/left/right, power, etc...) can somebody make a kind of schematic for me?
Surfing in the web I just found some pictures of the harnesses wired; now I'm trying to "guess" wich colors gets to each pin. Hard work...but what scares me more is to make somthing wrong and burn down the device...
Any "solver" please??? Thanks anticipated to all
Dan from Argentina
KaeZoo
  • 156 Answers
SOURCE: Fade button - does this system have one?
You can download an owner's manual for your CD player from this link: http://www.blaupunkt.com/us/downloads_1.asp
Posted on Mar 07, 2007
SOURCE: vw beta car radio, made by blaupunkt
To switch the system on, push the button left. When blue background light appears with the word "Safe" en ter your code. Example: code is 3527 push button nr1 3x, button2 5x, button3 2x and button4 7x. Confirm by pushing button 8 or 9. When the correct code is entered the system will go in operational mode. If the incorrect code is entered "Safe" will appear again. Good luck.
Posted on Sep 10, 2008
SOURCE: rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Posted on Apr 06, 2009
schast
  • 56 Answers
SOURCE: Need rear panel drawing or install instr for Heidelberg CD51
Crutchfield has the manual available for download here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/023/023HDLCD51.PDF
I saw a picture in the manual showing where the various connectors plug in. You should be able to tell from there what the orientation should be. It was page 29 of the PDF.
Posted on Feb 16, 2010
Testimonial: "Thanks very much for the information. This is a more complete version of the manual than the one that I have, and it contains the information I need. "
pctech1
  • 1940 Answers
SOURCE: I just purchased a new
I would try removing power to the unit, disconnect the microphone and usb cables, restore power to the unit and try again.
If it still says TELEPHONE, try the following:
Resetting the device (NORMSET)
You can reset the device to the factory settings. Your personal settings. e.g. your welcome text, will be deleted in the process.
  1. Press the MENU button 0.
  2. Press the LEFT (
  3. Press the rocker switch UP or DOWN to select the "NORMSET" function.
  4. Press and hold down the OK button 0 for longer than 4 seconds. "NORM ON" briefly appears on the display. The factory settings are restored. The radio briefly switches off and automatically on again during the process.
Note: If you press and hold down the OK button for less than 4 seconds, "NORM OFF' is displayed. Your personal settings are retained. Press the OK button to select adifferent function, or press the
DIS-ESC button to exit the menu.
If the display still says TELEPHONE, try the following:
If the display message of the device was set to TELEPHONE, try pressing and holding the power button for 2-3 seconds to turn on the device.
You may need a software update for your device.
You can update the software of this device without removing it. New software versions can be found on the Internet under www.blaupunkt.com. The software is transferred to the device with a USB data carrier.
Note: Please observe the information obtained at www.blaupunkt.com for handling the downloaded file and for installing the software on your device.
  1. To start the installation, connect the USB data carrier with the new software to the device.
  2. Press the MENU button 0 .
  3. Press the
  4. In the System menu, press the rocker switch Up or Down repeatedly until the "SW DNL" menu item is selected.
  5. Press the OK button to start installing the new software.
Posted on Jun 23, 2011
I ifound my O2 sensor with 5 inches of lead cut and frayed( 4 conds) cannot locate where this now cut cable ran to. Like a female connector or maybe even a cable w 4 conds in it dangling maybe the...
Likely the wires tore out of the connector. That should be somewhere in front of the sensor, attached to the floor board. New sensors are sold with and without the connector attached. Best to buy one pre-built to avoid getting the wires in the wrong positions (only a few $ more than "universal" type). When installing, route the wiring away from the exhaust and make sure it does not hang down.
Once installed, check the fuses in the power distribution center and make sure none are blown. (can happen if one of the wires shorted when they pulled out).
May 26, 2011 | 1993 Jeep Grand Cherokee
Tip
Affordable Locksmith Company Las Vegas NV 800-779-8530 Locksmith In Las Vegas NV...
Affordable Locksmith Company Las Vegas NV 800-779-8530 Locksmith In Las Vegas NV Car Lockout- Las Vegas NV
24 Hour Locksmith Las Vegas NV provides fast, reliable, professional 24 Hour 24 Hour Locksmith Las Vegas NV services at extremely competitive rates. At 24 Hour Locksmith Las Vegas NVs we stand behind our workmanship - 100% client satisfaction guaranteed. At 24 Hour Locksmith Las Vegas NVs we have a fully equipped mobile machine shop available 24 hours a day 7 days a week, we service most major lock brands and associated door hardware, including the brands we do not sell.
http://global-locksmith.com
At 24 Hour Locksmith Las Vegas NV we offer fast, professional and experienced locksmith services. Our technicians are equipped with the latest modern technology and are available 24/7 at your request.
24 Hour Locksmith Las Vegas NV provides services such as Residential Locksmiths, Specializing in:Fast lock out services, Locks installed & Repaired, Re-keys & Master Key Systems, Window Guards & Grills. Automotive Locksmiths, Specializing in: High Security Cylinder Changed & Re-Keyed, CCTV, Card Access Control, Intercom, Panic Devices, Safes Combination Change, Electronic Keypad and Keyless Entry. Commercial Locksmiths, Specializing in: Fast
Lock out services, Replace & Repair lost & Broken Keys, Precision Key Cutting Services for all make And models on site.
We provide 24/7 locksmith services such as:
Commercial Locksmithing, Specializing in: Lock Out, Deadbolt Locks Changed, Installed & Repaired, Re-keys & Master Key Systems, High Security Locks Systems, Intercom Systems Repair & Installation, Fire Proof Panic Bars Repaired & Installed, Peephole Installation.
Automotive Locksmithing, Specializing in: High Security Cylinder Changed & Re-Keyed, Closed Curcuit Television CCTV, Card Access Control Systems, Panic Lock Devices, Safes,Windows,Glass Doors & nvtes, Padlock, Combination Lock, Electronic Key, Magnetic Keys, Electronic Keypad and Keyless Entry, File Cabinet & Lock Picking.
Residential Locksmithing, Specializing in: keyless Entry, Key Cutting & Key Replacement, Emergency Vehicle Opening, Emergency Trunk Opening, Extraction of Broken Keys Locksmith, GM VAT Keys Duplication, High Security Vehicle Key Duplication Locksmith, New Ignition key and Transponder Chip Key.
RESIDENTIAL LOCKSMITHS COMMERCIAL LOCKSMITHS AUTOMOTIVE LOCKSMITHS
Deadbolt Lock and Key Replacement Car Lock Out
Knob Installation Window Lock Replacement Vehicle Locksmith
Cabinet Lock Replacement Re key and Master Key Install Lost Transponder VAT Keys
Closet Locksmith Safe Lock Repair & Install Automotive Lock Repairs
Safe Lock Repair & Installation Office Lock Replacement Ignition Key Replacement
Desk Lock Repair Replace Mailbox Key & Lock Automobile Lock Out
Master Key Installation Industrial Key Duplication Motorcycle Ignition Repair
Master Key Cutting Office Door Lock Picking Car Lock Out
High Security Cylinder Locks Replace Lost Office Keys Panic Lock Devices
House Lockout / Open Door Locks Store nvte Pas Locks Opened Combination Locks Opened
nvrage Lock Replacement Office Door Lock Out Emergency Trunk Opening
High Security Locks Opened Deadbolt Locks Changed Emergency Vehicle Opening
Domestic Locksmith Re keying Master Key Systems Key Cutting
Extraction Of Broken Keys Electronic Keypads Car key Replacement
Peephole Installation GM VAT Key Repair and Install Transponder Chip Key
Intercom Systems Repair & Install Keyless Entry Magnetic Keys
locksmiths Las Vegas NV
locksmith in Las Vegas NV
locksmiths in Las Vegas NV
locksmith Las Vegas NV
sandy springs locksmith Las Vegas NV
a locksmith Las Vegas NV
auto locksmith Las Vegas NV
Las Vegas NV locksmith services
Las Vegas NV locksmith reviews
emergency locksmith Las Vegas NV
commercial locksmith Las Vegas NV
car locksmith Las Vegas NV
on Apr 21, 2010 | Computers & Internet
Have a 2006 victory jackpot and lost the lights on the entire left side. Put lowering kit and it rubbed wire harness down to bare wirers. fixed wires and added a side mount plate bracket w/light and wired...
Hi, Thepokerboyz the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
03 06 Kingpin Vegas 8 Ball Ness Vegas Ness Kingpin Service Manual pdf
Motorcycle Service Parts Part Finder Victory Motorcycles Store
Owners Manuals Victory Motorcycle
Victory Vegas Jackpot 2006
Victory Motorcycles
Jul 12, 2017 | 2006 Victory Vegas Jackpot
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Jun 05, 2010 | Kenwood Car Audio & Video
Como soluciono el error sc300 de la ricoh 2060SP
sc300 on a Ricoh 2060 is a corona wire error. Typically what happens is the corona wire has snapped, and a new wire needs to be installed.
May 28, 2010 | Ricoh Aficio AP3800C Laser Printer
Were do you hook up the two wires under the hood for trailer brakes on a 2000 silverado
Sometime around 2000, GM started putting trailering pre-wire harnesses in the vehicle. Your truck may have this harness built in and would greatly simplify brake controller installation. Look under the glovebox and see if there is a wire harness tied off. There will be four wires in this harness, which should be run over to the steering column to use it. Most trailer brake controllers are compatible with this harness.
The four wires in the harness are: Red, 12vdc; black, ground; blue or purple, brake pedal; and brown or white, trailer brake wire to seven pin, four pin, or five pin connector at trailer hitch, if your truck came from the factory with a trailer hitch.
If you are adding the hitch and do not have the four wire harness, the under hood wires from your brake controller are Red, connect to one of the studs under the distribution box cover (the distribution box is on the driver's side against the firewall. Underneath the cover are two large threaded studs which are hot from the battery all the time); and the other wire from your brake controller would have to be run the length of the truck along the frame, tied off in several places, to the trailer hitch connector on the bumper. Follow the directions that came with trailer hitch wiring connector to connect this wire to the proper pin in the connector.
If this has helped you, great, and please remember to vote/comment.
Feb 21, 2010 | 2000 Chevrolet Silverado 1500
Help in wiring up plugs from car to trailer
There should be a pre wired conector for your truck at advanced auto or local auto parts store. These are simple to install and consist of unpluging a connector on the bottom of your truck and connecting to the pre wired harness.
Feb 08, 2010 | 2007 Toyota Land Cruiser
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is www.crutchfield.com. Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
Looking or vega usb 2.0 camera driver
I've got a webcam, all over branded as A4TECH "PK-30MJ"
but listed as "Vega USB 2.0 Camera" in the devices
http://a4tech.com/ennew/driver/CameraJ.zip recommended as optional drivers to use interpolated @800x600 video, doesn't
Mar 01, 2008 | FMI Portable Webcam
Blaupunkt Las Vegas CDM147 CD Player Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
