Question about Panasonic KX-P1150 Matrix Printer
How to stop the stop the printer into moving to the next page after printing a single line
If i try to print a single line.The printer after printing takes the whole page and gets to the next page.I want the printer to stop moving into the next page.It just causes unnesssary wastage of paper. How can i solve the problem?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 31 Answers
Set up the page length to desired length on the computer where the printer is installed.
Posted on Oct 26, 2012
ttech
  • 139 Answers
SOURCE: printing problems
Heiny,Ck This see if it Helps ttech http://www.fixya.com/howto/h153196-check_printer_run_out_ink
Posted on Jul 23, 2007
  • 76 Answers
SOURCE: how to RESET counter
Of course, the printer settings can be changed via the standard print options menu in Windows but to reset the counter is done when a new cartridge is installed. But this is how I would proceed... Since the printer and the cartridge are in "cahoots", I'd not give them the chance to communicate. Do this: Place some tape over the electronic contacts on the cartridge. (This prevents the printer and cartridge communicating) Then... Setup another printer icon using the HP Laserjet 4 (MS) printer driver. (This ensures no communication between the installed software and the printer). This should allow you to print some more, but not duplex of course. Remember to shake the cartridge from side to side in order to loosen impacted toner. ZT3000 "Beta tester of "0"s and "1's
Posted on Aug 19, 2007
  • 300 Answers
SOURCE: Print is obliterated with 4 broad hoziontal strips on paper
The green roller is the OPC drum, and as with many panasonic laser printers the cleaning mechanism doesn't work properly. The only way to solve this is to replace the unit.
Posted on Jun 19, 2008
  • 212 Answers
SOURCE: prints one line per page
check your printer settings. go to preview print page before printing. Might have to uninstall printer and reinstall it again. Hope that helps You.
Posted on May 24, 2009
digecorp
  • 92 Answers
SOURCE: stop printing test page when installing a new cartridge
It is a test alignment page and MUST be printed in order for the printer to align the cartridges, to avoid one colour over there, another here etc. If it is an all in one, you will need to scan it after it prints. Otherwise, there will be a scanner inside the printing part. There is no way to stop it unless you change the firmware and end up with a printer that can't print correctly anymore.
Posted on Apr 12, 2010
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
Mar 12, 2011 | Canon MP610 Photo All-In-One Printer
My HP 5500 stops printing jobs on its own. If I hit continue, it keeps printing the same job and not moving on to the next one in line. It also prints all of page one and page two, but I have to pull...
Try unplugging it for 10 minutes to reset it.
also clear out all print jobs on the computer and then try again and let me know what the situation is after following the two directions I gave.
thanks
May 05, 2008 | Office Equipment & Supplies
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have Epson Passbook Printer having some printing problem
this is problem of software you are using to print(ie: word ,notepad etc) plz check the setting and try again.
check page setting ,properties,prefrences.
it is due to page layout also(ie: letter,a4,a5 etc)
Jan 24, 2009 | Epson Passbook PLQ-20 Matrix Printer
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Form won't line up
your feed assembly needs to be replaced, the gears wear out on them and the next thing you know, it's moving on it's own.
t
Nov 17, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Printronix p5005b line skip problem
yeah I ran into this once, set the printer up to ethernet and not auto switching, i think thats what it was.
Dec 10, 2007 | Printronix Line Matrix P5005B Printer
Prints lines of garbage
This sounds like a driver issue, the wrong driver may be in use or may be corrupted. Go into Control Panel > Printers and delete the printer, then reinstall it using the drivers that came with the printer. Let me know how it works out!
Jun 06, 2007 | HP LaserJet 2550L Printer
Panasonic KX-P1150 Matrix Printer Logo
94 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
