Question about Maytag HAV3460AWW Top Load Washer
HOT WATER NOT COMING INTO MACHINE
The hot water line is connected properly, however, hot water does not come into the machine; when I turn to Hot/Cold, nothing happens, when I turn to warm/warm then water comes in but its cold. what could be the problem?
    Sergeant:
  • 311 Answers
Lets see hear.what the water fill hoses are connected to is call the water fill valve.when you select a water temp.,electricty will then go to ither water valve coil or both for warm.so if your not getting hot it could be first that the fill screens at the hose at the water valve is blocked .but most of the time thats not true of hot because minerals drop out in the water heater before getting to the water valve,unlike the cold water.so if screen is clean,next would be voltage to the water valve.if its getting voltage but not working then its the water valve.if its not getting voltage then use the wiring diagram to see what componet is before the water valve.may be water selector switch or timer
Posted on Jan 03, 2009
Just removed an old Moen one handle pullout kitchen faucet and installed a brand new updated version. Unable to get hot water line to work properly.
some new faucets come with there on supply lines when you tighten one will twist at the top near the faucet look under the sink to see if this has happened. i've had it happen not long ago
Apr 04, 2016 | Moen Plumbing
How do I change a water inlet on my washer WHDSR315DWW
remove lid the inlet valve/s have 2 wires 1 sml black hose 1 screw on inlet hose and 2 screws wich hold it to cabnet
Mar 03, 2015 | Washing Machines
What is the A:09 code
Code A09 means there is a problem with the water supply. Ensure your water is turned on completely, unplug the machine for 1 minute and then plug it back in. If the code persists, you should turn off the water and remove the supply lines. There is usually a filter in one end of each hose or at the water valve hookup. Ensure that the filter is clean and replace it. If you have done this and you know that you have good water flow through the supply hoses, I would suspect the water valve solenoid(s) as being defective.
Dec 22, 2014 | Whirlpool LSR5132PQ Top Load Washer
No Full Hot Water wash
the hot selection only tells the machine to turn on the house hot water to the machine
if you have it on warm , then both taps will be working
if you want a really hot water wash , there will be an element in the tub to bring it to temp
naturally an energy saver will not waste money heating hot water
Sep 15, 2017 | Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
Cold water doesn't run into washer on any part of the wash/rinse cycle. Checked cold water line but not plugged uphecked back of washer where water line connects and no clog there either. Makes a...
Sounds like the valve isn't working properly.
One way to test is to turn off the water supplies and at the back of the machine switch the hoses.
Turn on the water and see if you get cold and not hot . If so replace the valve assembly
Jan 23, 2011 | Maytag Washing Machines
Cold Water comes out hot at first and then the hot comes out cold
did you just install the unit? if you did, then you have the line cross from hot to cold and cold to hot, just reverse it. If it just started and no one has been messing with it, you may have the water valve problems. its a unit inside which regulate the valves by serenoid control by the motor control timer although it can also be the motor control timer is not working properly to regulating the water valve unit. The motor control timer cost around 200.00 bucks and the water valve cost around 76.00 bucks..Im going to guess if your water valve working properly than it will be your motor timer. you can test the water valve by testing all solenoid to see 2 hot and 2 cold is working, their is total of 4 solenoid. its located in the rear of the panel where the water line connects to. and here is the number for parts if you going to do it yourself 1-877-477-7278 I hope that help some..good luck!
Jul 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hot and cold water mixup
Switch the lines and grin and bear it!!
Jun 20, 2009 | Whirlpool Washing Machines
Check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
May 17, 2009 | Electrolux EW1000i Front Load Washer
Cold water not running.
check the cold water selenoid on the water valve
May 05, 2008 | Washing Machines
Maytag HAV3460AWW Top Load Washer Logo
219 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
