Question about Sanyo EM-U1000W Microwave Oven
Microwave is on but the keypad doesnt respond
I came home from college and I brought my microwave back and when I tried to plug it in at home it didn't work. The display screen lights up, but no numbers come on, and when I press the buttons on the keypad theres is no response from the microwave. The light bulb turns on when I open the door, and when I unplug it and plug it back in it makes a beep, but thats about it. What can be wrong with it?
  • Sanyo Master
  • 9,156 Answers
It may be in child lock mode. Your owner's manual will cover that. On the Sanyo EM-S5595, for example, you turn the child lock off and on by pressing and holding the STOP/CLEAR pad for 3 seconds. Yours may be the same. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, may be damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top, direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or by infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Instead apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If it looks like you need service, this is a good place to start: http://www.sanyoservice.com/
Posted on May 14, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Having an issue with the keypad - not responding
I would contact Samsung, they seem to be aware of the issue with the control panel failing on there otr model and are replacing them free of charge under there "epidemic warranty"
May 06, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Sep 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Model 565.60512000 manufactured 3/2000. there is a L besides the time. I have lost the manual so do not know how to unlock. Instead of seeming locked, I can enter cook time but then the microwave turns...
HELLO.
The problem with your microwave's touch pad needs some simple troubleshooting steps to rectify the problem.
Reach me for further assist.
Thanks.
Sep 06, 2011 | Kenmore 63652 Microwave Oven
I have GE microwave oven model JVM1740DM1WW-1000W. the key pad 1 to 6 on express is not working. all other key pad works. how to troubleshoot this problem?
you can try removing the outer cover and being careful,check all ribbon cables to the keypad by removing if they are plugged in and not soldered to the keypad circuit board and re plugging them back in,if this doesnt solve the problem you will need to replace the keypad board
Aug 07, 2011 | GE Spacemaker JVM1740 Microwave Oven
Samsung microwave has numbers on the display but keypad doesnt respond
It's probably a defective membrane keypad.
But without the full model number with suffix, we can;t give you an estimate and let you know your options.
Please post a new help request with the full model and symptoms.
Jul 02, 2011 | Samsung Microwave Ovens
Magic chef touch pad doesnt work
I don't have Magic chef, however, I would try hitting cancel, unplugging the microwave and waiting a few minutes, then plugging it back in to reset it. Alternatively, you could go to your manual under troubleshoooting. I wish that I could help you more with this. Good luck to you. Please let me know if you figure this one out.
Jul 31, 2008 | Emerson MW8626W Microwave Oven
No key's work. Display and inside light is working
The Keypad is either faulty, or disconnected. Open the case, and remove the screws, holding the outer shell on. Inside, there should be a small board that covers the Keypad. Check to see if there is a ribbon cable, or some other type of connection going from the board to another part of the microwave. If all of the wires are connected, then you will probably need to replace the keypad.
Jan 26, 2008 | LG LMVM1955 Microwave Oven
Sunbeam microwave doesnt work
i just brought my sunbeam microwave like two days ago. and it will not heat up
Jan 22, 2008 | Sunbeam SMW777 Microwave Oven
Sanyo EM-U1000W Microwave Oven Logo
273 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Etronix
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
