Question about Miele Revolution 600 Bagged Canister Vacuum
Rotating brush doesn't rotate
Rotating brush stopped rotating came on sporadically but now nothing.
2 Suggested Answers
Vacuum Guru
  • 78 Answers
SOURCE: My vacuum cleaner brush stopped rotating. Just
Almost certainly you have broken the drive belt. THese machines have a rubber belt that is designed to snap if you get the roller brush stuck on something. The most common reason for this to occur is that you **** up the end of a rug, the curtain or a sock. This will stop the roller but the drive shaft will continue to spin which chews through the rubber belt.
What you will need to do is buy a new belt and fit it on.
Hope this is helpful for you. If it is please take a moment to give me a rating. If you are in Australia and need somewhere to get you miele belt from try nelsonvacuums or VacuumSpot.
Posted on Dec 22, 2010
How do i fix the brush on my babyliss rotating hot air brush as it has stopped working after two goes..
you need to replace the drive belt look for screws on bottom and access plate left or right.
Jan 21, 2015 | Filter Vacuums
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
My rotating brushes have stopped rotating
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
May 07, 2012 | VAX Appliances Vacuums
My dyson DC19T2 brushes have stopped rotating
Hi Deborah,
I'm sorry to hear you're having difficulty with your DC19T2. If the brushbar in the turbine head is not rotating, I'd encourage you to follow the steps shown in our online Support guide to make sure everything is correct with the machine:
http://www.dyson.co.uk/support/dc19t2/dc19t2-animal/my-machine-is-not-working/check-the-plunger
This should resolve the issue, but if you'd like any further assistance or advice, please give us a call on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 06, 2012 | Vacuums
How do I reset the brush bar please
If your DC14's brushbar doesn't seem to be rotating as usual, please follow the steps shown in our online support guide to make sure everything is correct with the machine:
http://www.dyson.com/support/help.asp?article=668&product=DC14-ALLFLOORS_US
Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've set the brush control to 'Hard floors' instead of 'Carpets'.
I hope this helps - if you'd like any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Mar 01, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
I can't switch from the brushless option to the rotating brush option.
You should be able to turn the brushbar on using the brush control on the cleaner's head, turning it from the 'Hard floors' to the 'Carpets' setting. For further guidance, you might find it helps to refer to the user guide supplied with the cleaner. In case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
However, if the brushbar doesn't seem to be rotating when the brush control is set to 'Carpets', it's probably best if you get in touch with us directly so we can help. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Oct 17, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Rotating head does not rotate
Check for broken belt in the brush roll compartment and replace
Sep 20, 2009 | Vacuums
Miele Revolution 600 Bagged Canister Vacuum Logo
24 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
