Question about Ariston Technologies Washing Machines
Can't open pre-chamber cover
The washing machine model is a Margherita A 1324. I can turn the cover to the left by nearly half a turn but it stops turning and will not pull out. Does it need to turn a full half turn before it will release?
zeusfaber
  • 247 Answers
SOURCE: washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Posted on Jul 17, 2007
Washer_tech
  • 164 Answers
SOURCE: Washing machine problems
it sounds like the lid switch might be misaligned.open and close the lid slowly and listen for the tell-tale click. if you don't hear the click then open the control panel and adjust the position.
Posted on Aug 28, 2007
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
rohityadav79@gmail.cm
Posted on Feb 03, 2008
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
My Ariston Margherita cde12x stops half cycle (approx 30mins) and the dial on right starts ticking noise . What can i do please?
Basically, it's an electrical problem. You need to unplug the machine and open up the back of the machine, and unplug all the connectors that are connected to the circuit board. Plug the machine back in and turn the machine on for 2 min. then power off and unplug it and reconnect all the connectors back to the circuit board and it should work.
Aug 09, 2016 | Washing Machines
My washing machine Simpson Model no 22S711 wont turn off when it is filling up with water
if it stops when you turn the machine off the problem will be that the pressure switch chamber is blocked unblock it should be ok
Sep 30, 2012 | Simpson Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Something has blown in margherita 2000 and can't open door
hmm sounds like a spring has busted inside your washer there and the diagnostic computer inside the washer was damaged so its not able to unlock its door....
Dec 16, 2017 | Ariston Technologies AL128D Margherita...
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Pump pre chamber lid wont open
I have a PWE8168 and assuming yours has a similar arrangement:
1) Switch off water and electricity feeds;
2) Pull the washing machine forward a sufficient distance to allow you to tip it back so that you can gain access to the area next to the pre chamber lid. I found my tool box was handly at propping up the front!
3) A torch is handy at this point. Lie on the floor, and use a pair of mole grip pliers to release the springs securing the pipe attached to the left of the pre chamber filter (looking from the front of the machine).
4) Note that if you have not been able to drain your machine already your should have some towels/cloths and (eg) a tuppaware container ready to collect all the water.
5) Slide the pipe off and you should be able to get your fingers into the pump pre chamber and fish out whatever is jamming both the pump and the lid. I got a 5p piece for my troubles!
I would not say that this is a particularly difficult procedure and apart from water collecting, should only take 20 minutes, including reconnecting the pipe.
Oct 25, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
