Question about Coby MP-C7085 MP3 Player
What do i do
When im on the main menu and click to go somewhere it says file sys err what do i do?
  • 7 Answers
***WARNING*** **This should wipe out everything on your player.**
If the file system is corrupted you have most likely already lost your files already. I would try to reset the player (use a pin to gently press the Reset button on the rear of
the player) and try again. If this works you should be able to reload your files back onto it.
If you need the manual for this unit it can be found here.
Posted on Jan 03, 2009
  • Kenney Williamson Jan 03, 2009
    If you still have the file system error after resetting I would try to format the file system from your pc.
    Use the USB cable to connect the
    player and the computer.
    Double click on My Computer, then
    right click "Coby" "MP-c7085"
    or "Removable Disk" and left click on
    "Format".
    At the "Format" window, click OK to
    confirm and the player will start to
    format (see figure to the right). When
    finished, click "OK" to close the
    Format window.
    If it said "Removable Disk", at the "Format" window, select "FAT 32" from the file system pull-down menu, then click "Start" to format the unit
    NOTE: Make sure you have selected "FAT 32" at the file system pulldown menu; otherwise, after formatting, the player will not work properly.
    Then, click OK to confirm and the player will start to format. When
    finished, click "Close" to close the Format window.
    This will resolve it if a reset does not.
Says "file sys err" and cant figure out how to reset all of it
There's a firmware update for the MP610 for the problem you mention.
1. Go to the support page:
http://www.cobyusa.com/?p=support
2. Enter MP610 in the Product Search bar, in the support page.
After entering this model player, all support will show up.
3. For solving the "file system error" coming up in the display:
Download the zip file: MP610_firmware_update.zip
4. Unzip the file with WinZip or WinRar
5. Read the pdf file for instructions, how to perform the firmware update.
When needing more help, just add a comment in this thread.
Apr 25, 2010 | Coby MP-610 MP3 Player
Coby mp610 files sys err
Please Try these steps to fix your Coby MP-610 MP3 Player.
Dec 19, 2009 | Coby MP-610 MP3 Player
My Coby mp3 player shows file sys err. when I press music or pictures ... it shows file sys err. Thank you
there is problem with the software installation. try re-installing the software. it might help. good luck!
Oct 14, 2009 | Coby MP550 MP3 Player
Coby mp610 says file sys err
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will correct your 'file sys err' message and have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Jun 22, 2009 | Coby MP-610 MP3 Player
My coby mp3 mp-610 keeps saying file sys err hod do i fix it
hope u got this fixed but if not i know where you can go to cobyusa.com and put the model number in product search the click firmware and download to ur desktop. open it up and u will have 24 grey boxes then plug in the mp3 and clik the firmware button right below box 24 one there is a green check in box 1 then its fixed and u can disconnect it and re add ur files
May 31, 2009 | Coby MP-610 MP3 Player
File sys error
http://http.vitalstreamcdn.com/cobyelectronics_vitalstream_com/software/MP610_Firmware.zip
Download that. It contains a firmware update that is meant to fix the "file sys err" problem. I got it directly from the Coby website and it works perfectly.
Jan 26, 2009 | Coby MP-610 MP3 Player
Jan 16, 2009 | Coby MP-610 MP3 Player
not responding the coby mp3 550-1g player on my computer
Dec 29, 2008 | Coby MP550 MP3 Player
the file system seems to be damaged ... format and reload ... and if possible upgrade the player software
Dec 07, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7085 MP3 Player Logo
49 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
