Question about Xerox WorkCentre 3220 All-In-One Laser Printer
Screen displaying paper jam 2 on xerox work centre 3220
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
Posted on Oct 23, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Posted on Jan 27, 2009
  • 4 Answers
SOURCE: Our XEROX Worcentre 4150 often jams and displays a
In the main door at the top in the middle there is a little black leaver that moves up and down if it gets stuck in the up position it thinks that there is a papper jam just check the little black lever and make sure its down
Posted on Jul 10, 2009
  • 239 Answers
SOURCE: Xerox M15i paper gets jammed above the fuser
This machine might have the vertical transport guides broken. The tips break when the white plastic guides are stained yellow.
You may need to have Xerox come out to do the repair, there is extensive work involved in replacing the part and other parts as well. You would need to make sure you have ordered the correct parts for this specific model.
Posted on Oct 17, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
HOW DO I REMOVE PASS WORD ON 3210-3220 XEROX WORK CENTRE IN FAX SET-UP?
You can contact a Xerox service center and see if they can provide the default password. In most of the WorkCenter MFP's the previous owner would seldom change the default. But if they did, the Xerox service tech can probably tell you how to reset it once you provide the serial number and proof of ownership.
Dec 24, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Hi there
Error 04,041.66
Solution 1:
Service Tools menu.
Solution 2:
Feb 03, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Paper Jam 8-112 when power on Xerox DocuColor DC 1250 Printer
You it is necessary to make sure visual(optic) to see the sensor(pick-off) of that node(knot;element), which(who) you is informed.Byvat that conk or клинят sensors(pick-offs) of the passing, electronics in this case her(its)(her) fault is practically excluded. Extremely(Most) seldom(rarely) such быват.I work(operate) 18 years I had 1 or 2 times, but only mechanical damages much(highly;very much) often were. The Sensor(Pick-off) conks or клинит, when remoove the stuck paper. I am simply(merely) run away that reason in sensor. Good luck you!
Aug 07, 2009 | Office Equipment & Supplies
Jul 09, 2009 | Xerox WorkCentre 4150 All-In-One Laser...
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
Xerox WorkCentre 3220 All-In-One Laser Printer Logo
457 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
