Question about Whirlpool MH1150XM Convection/Microwave Oven
Our 3 yr old microwave operates totally normal, with the exception of it quit warming today.
  • 4 more comments
  • jaredwoodruf Jan 04, 2009
    The model is MH1150XMS-2. Everything sounds normal. The light and the turntable work as usuall as well. You can even hear what appears to be cooking off and on during lower settings, which was normal, but there's absolutly no heat at all even on high settings. All sounds are totally normal. The door stops the operation and the display seems to work normal too. As far as I can tell, the only thing affected is the lack of heat. Could it be a simple fuse inside?
  • jaredwoodruf Jan 08, 2009
    I found the links and etc. great. Fortunately the problem wasn't any of the components. I tested each one and they all were ok. But when I went to remove the magnetron, I noticed the wire connector was extremely loose and a little corroded. I cleaned and tightened the connector. Put it back together and voila!!! It works. Thanks for all the help. I'm sure it would have been a pain without it. : )
  • Anonymous Jan 10, 2009
    whirlpoolMH6150XLT No heat, but everything else works.
  • chrisregula Feb 04, 2009
    whirlpool mh1150xms-4 no heating
  • matthubbell Mar 06, 2009
    Our Microwave is about 4 yrs old and doesn't heat. Last night during normal operation, we heard a loud noise and stopped the unit. When we turned it back on, it wouldn't heat. Everything else appears to work fine. It even sounds like it's going when we start it.
    Also, I noticed someone else posted an issue with the fan coming on whenever the unit is on. We've had the same problem for a year and just ignore it. Would be nice to have that resolved as well.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    What is the model number?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
    Please reply back with
    your brand and full model number from the tag so we can help you
    properly.
  • Whirlpool Master
  • 9,086 Answers
It won't be a fuse.
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here. Enter your model as "MH1150XMS2" with no dashes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
To test or replace the parts, you will probably need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Jan 04, 2009
  • William Miller
    William Miller Jan 04, 2009
    NOTE:
    I also meant to say that since it's less than 5-9 years old, the magnetron would still be covered under warranty.
    If
    it's within the magnetron portion of the warranty (usually 5-9 years)
    but out of the original full warranty (usually 1 year), then your
    manufacturer will cover the part cost, but not the cost to visit you or
    the labor charge to do the work.
    Whirlpool customer
    service is
    here and they may send you a magnetron (if needed) to install yourself or for a service tech to install.
    If
    nothing else, you can save about $75 by taking it to the shop yourself.
    Again, you can
    instructions
    here.
  • William Miller
    William Miller Jan 08, 2009
    As i said, "or a loose and possibly corroded connection on the magnetron's terminal."
    But I would not count on that fix to last if it's not very clean and tight.
    If it was too badly corroded we will cut the connector off the wire, strip the wire, run it through the hole in the terminal, twist it and solder it.
    Would this rate a FixYa rating from you?
    We're happy
    of our answer.
GE Profile microwave oven PEB7226SFSS quit warming food but appeared to be on/operate with light on/timer counting down. Installed door switches-now the microwave "works" only when the door is open
Sounds like on reassembly you reversed wires to door switch.
switch might have letters C NO NC (common, normally open, normally closed) one wire goes to C common, the other to NC normally closed. Try reversing the wires.
If you use meter measuring continuity meter on C and NO should be high resistance until you press switch.
meter C to NC measures low resistance until you press switch then measures high or infinity (open)
Sep 28, 2016 | GE Microwave Ovens
Panasonic nn-t9455sfx has no power
If total dead look for the fuse inside and make sure the circuit it is plugged into is active(has power).
Dec 12, 2012 | Microwave Ovens
5 yr old microwave has worked perfectly - until now. Put small amount of food on a safe plate in for 45 seconds. Plate suddenly cracked, was extremely hot - and food wasn't even warmed.
The plate wasn't microwave safe or has a crack in it that had moisture in it to cause it to split.
A new pyrex type glass plate will get it going again.
Mar 08, 2011 | Microwave Ovens
I have a Jenn air microwave and it just quit the other day while I was warming water. It is about 7 yr old. Is it worth fixing?
I recommend replacing it, as you said it is 7 years old and prices have dropped on the new microwave ovens making it more attractive to buy. The repairs with parts and labor will approach the cost of a new one.
Jan 24, 2011 | Jenn-Air Microwave Ovens
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
Kenmore microwave's exterior and buttons
Hi it is quite normal for the outside of a microwave oven to get quite warm to the touch. with regard to the buttons not working; this will be due to a faulty touch panel mebrane that will need to be replaced. They are not too expensive so is a viable repair
Hope this helps
Jan 07, 2010 | Microwave Ovens
We have a DVM Adora Spacemaker microwave. The unit was manufactured in May 2008 and purchased a few months after. When heating the unit would make a light clunking sound. This began after the first...
The unit was taken into a repair shop. The repairman said the magnetron shorted out and the unit failed. Fortunately, the unit had a 5 yr warrantee on the magnetron (1-yr on everything else). Total out of pocket costs are estimated at $65 to reinstall a new magnetron plus the aggravation of two weeks without a microwave. Those are pretty handy devices to be without!
Nov 14, 2009 | GE Profile Spacemaker Over-the-Range...
I have a 21y/o full sized Kenmore 700w microwave that I want to keep. Worked fine until this morning. Everything works except the heat.
Sadly Kenmore only offers parts for 10 years. The truth is a new microwave for 50 dollars will be much more energy efficient than your 21 yr. old model
Jul 12, 2009 | Microwave Ovens
Microwave Quit Heating
The Magnotron goes out on many of the lower priced models in the first yr.,(and some of the higher end ones too!) As the components there do most of the hard work. Better to just find a recycler who takes them and scrap it.
As for the replacement that sounds like an excellent idea!
Sep 02, 2017 | Emerson MW8778 Microwave Oven
GE Microwave quit
Hats off to your 20 year old GE machine. That is the the longest lasting microwave I have heard of. When they finally go out, they are done, there is nothing left to even do with them. Most of the parts are obsolete. However you might find a appliance store that still has one similiar to yours in their backroom that they use for spare parts for those like you who might need it. You might take it to them to see if it is worth repair.
I can say this, after 20 long years, the machine will cost more to fix, and for what you will spend on repair, you can buy a different one that can also be energy effiecient.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
423 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
