Question about Samsung ML-3051N Laser Printer
Paper jammed inside my printer near bottom
I have a paper jam but don't know how to release the paper which is visible at the base of the machine
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 31 Answers
Open front cover where toner cart is situated and remove cart.check and see if the jammed paper has fed into the machine and if so pull paper in the direction it is feeding into the machine.
Posted on Oct 26, 2012
flopez
  • 161 Answers
SOURCE: Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Posted on Oct 04, 2007
shivam4529
  • 150 Answers
SOURCE: Paper not feeding in the
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
Posted on Jun 18, 2008
SOURCE: Paper Jam Error 2
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to www.samsung.com - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Posted on Mar 18, 2009
SOURCE: CLX-2160N Paper Jam?
my printer Samsung CLX-2160 give me the message "paper jam", but I checked a lot of times inside and there is no paper. What's the real problem? How can I solve?
Posted on Sep 07, 2010
SOURCE: Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Posted on Aug 27, 2011
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
Hp 4700 paper jam in duplexer
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed. Note: I have no proprietary interest in any supplier that I may suggest.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
I don't know whether or not you want to clear the jam or to find a cause for the jams, so let's cover all bases.
To clear a jam, CLICK HERE
2. Your printer is a compromise that must contend with different moisture content papers. Moisture content varies with the amount of humidity in the ambient air.
To rectify the problem(s) install a paper jam repair kit that is printer specific and the problem should be eliminated. CLICK HERE for such a kit.
May 28, 2012 | HP LaserJet 4700 Printer
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
Paper is jammed and cannot get it out
It can vary a lot from one printer to the next, but I suggest this . . .
Turn off the printer at the mains supply (you really do not want it grabbing your fingers inside) :)
Look down the back where the paper gets taken in, and see if any paper is visible in there, if so, carefully remove it, you may have to use some long handled pliers or grips of some kind.
If it all seems clear, the paper jam may be a bit further inside the mechanism. Inside there are several rollers that grip & guide the paper sheets through, and this is where paper is usually stuck.
Open the printer lid (not the scanner, but the whole lid as if replacing the ink cartridges. And check carefully nothing is hiding in there. Most paper is white and so easily visible, but some gets ink on it when jammed and may even be black and near invisible in that dark area.
Be very careful to not damage any of the mechanism inside, as they are usually very sensitive to things being poked around in there.
If after all this, no paper can be found, you may need to take the complete lid off the printer to get right inside, which is a bit of a bigger job.
Also, unless you are 100% sure that it is paper blocking it up, unplug all cables, and gently turn the printer over to see if anything falls out :)
I fix printers as an engineer, and have found, coins, pens, biscuits, sweets, paper, labels, pencils, a sandwich!!, toys, hair ties, elastic bands ! Never found any small animals in one yet, but there's always tomorrow :D
Good luck with it.
May 18, 2011 | Lexmark X2670 All-In-One Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper jam???
    Follow these steps :
    1.1
    Remove all paper from the trays. This will prevent further jams during the clearing.
    2.2
    Remove the covering to the printer's outer case to expose the jam. Locate the jammed paper to ensure there is not another problem causing the stall.
    3.3
    Pull gently on the jammed paper, taking care not to tear it. In most cases, this will remove the jam.
    4.4
    Press the flashing "Printer Jam" button. This will allow the rotors to turn and facilitate the release of the jam.
    5.5
    Turn off the printer and firmly pull on the jammed paper. Be careful not to tear it.
    6.6
    Remove remaining paper shreds. if a tear occurs, remove any residual paper that may hamper printing.
    7.7
    Refill the paper tray and try printing again. If the jam persists, repeat the process and search for more paper.
    Oct 29, 2010 | Canon ImageClass D861 Printer
    Canon MP470 keeps saying "paper jammed"
    I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
    Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
    Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
    Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
    1. Turn off your printer
    2. Open all trays and remove any paper stuck there
    3. Locate the button to open the printer, open it and remove any paper stuck there also.
    4. Repeate the above step for all buttons that you can find to access the inside of the printer
    5. Close all doors and put back all trays
    6. Turn on your printer
    NOTE: Please rate our help to keep this free service online.
    Dec 07, 2009 | HP Photosmart C7280 Laser Printer
    Samsung ML-3051N Laser Printer Logo
    153 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
