Question about Photography
My 35mm film won't load. It keeps rewinding
I took the old film out (never exposed, but out of date. Now I can't load a new film as it keeps being rewond. Camera confused.
    Novelist:
  • 154 Answers
Solution: Repair or replace auto-rewind system.
Cause: The built in auto-rewind system that supposed to work when film is finished but because it is faulty it receives wrong signal when film is lloaded. So the camera thinks the film is at the end of the roll.
Possible cost: $65-$75
Posted on Nov 03, 2012
dll932
  • 40 Answers
SOURCE: Camera Rewinds New Roll of Film
Check the camera and the manual to see if there is a control to override the auto rewind; it may be set to rewind. Other than that, check Mikon's website for support info.
Posted on Jun 23, 2007
pontelemon
  • 538 Answers
SOURCE: new film will not load or advance in my Canon rebelx 35mm
Gears are broken in Advance Assembly.
Posted on Apr 02, 2009
BeninVa
  • 389 Answers
SOURCE: I have an old 35mm Canon Sure Shot 70 Zoom. There is
You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
Posted on Dec 15, 2009
  • 102366 Answers
SOURCE: I dont know how to load my Nikon 35mm camera. I need instructions
Pull up the film rewind knob to open the back.
Drop the cartridge into the well on the left and, while rotating the rewind knob, push it back down to secure the cartridge.
Pull the leader across and insert it into any of the slots in the takeup spool.
Make sure the film perforations engage the sprocket teeth.
Alternately wind the film lever and press the shutter button until the perforations on both edges of the film engage the sprocket teeth.
Close the camera back, making sure it latches.
Take up the film slack by rotating the rewind knob in the direction of the arrow until you feel resistance.
Make blank exposures until the counter shows "1".
There's a fuller, illustrated set of instructions in the manual, which you can download from http://www.butkus.org/chinon/nikon.htm
Posted on Feb 03, 2010
Obertelli
  • 3006 Answers
SOURCE: how to rewind roll film in Lomo Action Sampler
To rewind the film on your camera you push down on the rewind handle on the top left of the camera (as viewed from behind) and turn the rewind handle clockwise until no more resistance is felt.
Once the film has been rewound, slide down the catch on the left edge of the camera body and open the door on the back of the camera.
Courtesy of alfredklomp.com you can download part one of the manual here and part two here.
If after all this, the camera is broken then it cannot usually be repaired: it's designed and built as cheaply as possible as a toy camera and is only designed to last for a few rolls of film. Spare parts are not available, but some broken parts can be adapted or fabricated from whatever is to hand to do the job.
Based upon the question you asked, my reply should have solved your problem so please take a moment to rate my answer. If the problem has not been solved then add a comment instead and I'll be happy to provide further assistance.
Posted on Mar 24, 2010
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
When I insert a new roll of film into my Canon Rebel S 35mm SLR, it automatically rewinds the film instead of winding it onto the spool. I can't figure out why it's doing this.
this is normal, as these cameras are designed to wind the entire film to the take up spool then as you expose the file will roll back into the cassette. this was a feature that canon devised to protect already exposed film when the back cover is inadvertantly opened.
Aug 17, 2013 | Canon EOS Rebel X 35mm SLR Camera
Nikon f601 won't rewind
needs repairing at a qualified shop
Sep 06, 2012 | Nikon F601 35mm SLR Camera
How do I export the film after shooting?
When the camera exposes the last frame, it will rewind the remainder of the film back into the cartridge. Open the camera the same way you opened it to load the film and remove the cartridge.
If you need a manual, you may download a copy from here.
Aug 11, 2012 | Nikon N55 35mm SLR Camera
Hello, just found my 35mm ae-1 camera. took some pictures and its not rewinding back up . little crank is moving but film is not going back in. am I missing a step?
Did you remember to push the rewind release button, on the bottom of the camera first? Failure to do so will either not allow you to rewind the film (without applying a lot more force than needed), rip off the film sprocket holes, damage the camera's internal gearing, or any number of other nasty things.
There should be a small button on the camera's bottom baseplate, press it in and it should rewind smoothly.
Sep 05, 2011 | Canon EOS-AE-1 35mm SLR Camera
Do you keep advancing the film til you get to one. I have but it still shows S. Should i start all over
When you advance the film, does the rewind crank turn counter-clockwise? If not, then you haven't loaded the film correctly onto the take-up spool and must start again.
Aug 17, 2011 | Minolta X-370S 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
I can not open the back of the camera to load new film and battary
The battery gets loaded at the bottem of the camera, and if you use the rewind now which i believe is on the left hand side on the top, if you pull that up it will release the chamber of the back, but make sure you press the button on the bottom in and rewind the film before opening the back, otheriwise your film strip is useless. cause its exposed. :) good luck
Aug 29, 2010 | Vivitar V3800N Zoom 35mm SLR Camera
My Canon EAS Film Rewind Knob is rolling my new film back into the cassette instead of into the camera...please help.
That's what the rewind knob is all about: It will allow you to rewind the film back into the cassette to avoid it to be exposed to the light and therefore losing your pictures.
When loading the film you must insert the film into the receiving spool by hand while the camera back is open. Make sure to advance the start enough so that the spool will 'stick' to the film.
Dec 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
Photography Logo
135 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
